Puzzled by lack of reception
Bushwack
Los Angeles
I have a Uniden BCD396XT. Located in Los Angeles, I can receive frequencies that are 30+ miles away w/ three mountain ranges and the downtown skyline between us. Yet I can't monitor PD and FD frequencies (Santa Monica or Culver City - 470.XXX and 482.XXX)) that are less then five miles away (with simple topography). Is there anything I can do (i.e. is there certain programming I can do for individual frequencies within the scanner) to increase these signals? I've gone ahead and ordered a telescopic antenna on the slim hope that will help.
Thanks for your time.
Rt169Radio
CT
It might be multiple signals that are overpowering the scanner that are coming from various towers close by.Or it might be that those freqs are locked out on your scanner.
nanZor
Clark
Venice, Calif
Santa Monica PD is Encrypted. The BCD396XT will mute an Encrypted signal so you will hear nothing.
I also am in LA on the Mar Vist /Culver City border. I monitor Culver City almost contunually with perfect
results. The trunked frequencies info. is here
Interagency Communications Interoperability System (ICIS) Trunking System, Various, California - Scanner Frequencies.
The BCD396XT requires the correct Motorola Bandplan which is here for Culver City.
Lower/Base =480.500
Upper =485.2375
Step = 12.5
Offset = 380
If this Bandplan is not programmed correctly, the scanner will not scan Culver City.
Clark
