Question about APX Bands
Gwebb258
Hello,
I am looking to purchase my own APX6000XE or possibly an APX4000 radio, but need a few questions answered first.
My county's radios operate on a UHF 450-520 MHz band.
1. Are UHF R1 and R2 radios different? I did some research and it seems like R1 is a lower band and R2 is higher, but nowhere had a concrete answer. If I were to buy an APX radio that is UHF R1, can I swap out the antenna for UHF R2? Or is the radio strictly programmed for that specific band.
2. Also, what are the ranges for R1 and R2?
Thank you very much
GTR8000
NY/NJ Database Guy
BEE00
They are separate ranges in the APX series, determined by RF hardware, not the antenna. Only the 8x00 series includes the full UHF range as a single option, all other radios you must choose the correct range (or both UHF R1 and R2 in a dual-band 7x00)
UHF R1 380-470
UHF R2 450-520
Outerdog
T¹ ÆS Ø
Go straight to the source next time.
N4KVE
PALM BEACH, FLORIDA
If the freq’s you need to operate on are between 450-470, you could use either split radio. If you need it to work above 470, then you need the R2.
GTR8000
NY/NJ Database Guy
BEE00
Probably to accommodate NYPD?
Not a bad guess, but NYPD has 482 and 485 channels, so I don't think it would make sense to stop at 480. 420 MHz is only used in the Buffalo/Niagara area in NYS.
ElroyJetson
Glad I read this topic. If I had at any point planned to get an APX with UHF in it, now I know that only R1 will allow 70cm operation.
Kind of surprising that R2 isn't even editable to enable the 440-450 range but it is what it is.
So R1 is the version I'd seek. Another benefit is it would allow the possibility of monitoring some UHF-L federal systems.
UAT_978
UHF R1 380-470
UHF R2 450-520
A bit of a rarity, but the APX7000 could be had in UHF R1 and UHF R2 for 380-520 coverage. I have only seen one or two come across my bench, but they did make them.
so happened while looking thru firmware notes a few days ago and saw this topic
What does this mean? RTTE governed countries?
APX R17
New/Replacement Products
Abstract: “BN” Radios UHF-R1 Extend Frequency to 480 MHz
System Platforms Affected: All
Special Configurations: Applies to radios in RTTE governed countries
Description: Operating UHF 1 band for “BN” model radios have been extended from 380-470MHz to 380-480MHz. APX 6000, APX 6000 XE, APX 6000 LI, APX 5000, SRX 2200, SRX 2200 ULP “BN” models
UAT_978
APX R17
Short answer: European radios and does not affect radios in the NA market.
