BCD436HP/BCD536HP: Question about discovery
Gary985112
So when I run a long Discovery session and export that Discovery session to sentinel, what's the quickest way to listen through the recordings and see what is interesting? And once I find some frequencies that may be of interest, is there a quick way to just discard of the ones that I don't care about and bulk ad the frequencies that I do want to scan to a favorites list? Just wanted to see if there was a quick way to do this. With the goal of just moving the frequencies that I like to a favorites list to listen to them more.
Thanks!!
rumcajs_tr
Europe, Czech Republic
Generally, there is no way how to tell which frequencies from discovery hits are interesting without listening to them.
However, here is my way how to clear things up a little.
After downloading discovery run to the Sentinel, I perform these actions:
  1. Delete all records with Avoid tag set to On (that means I pressed avoid button during discovery for whatever reason)
  2. Delete all records with Duration equal to 0 sec or 1 sec (that means no audio recorded or only a short burst)
  3. Delete all records with Duration equal to hits count (that means average recording time for each hit is less or equal to 1 sec - probably data bursts only)
  4. Quickly review all records with Duration equal to your Record duration setting (that means the record duration overflow was triggered, so it might be just a constant carrier or noise on the frequency - when this is the case delete them)
  5. Delete all records without CTCSS/DCS/NAC/CC (well this one is tricky, but my personal experience is that 99% of agencies do use some kind of subtone or signalling)
After this, you should have several frequencies remaining to listen to...
As for the transfer of the frequencies to new FL, I think the copy/paste works well in Sentinel. Or you can copy to excel, modify and copy back.
Gary985112
Hey thanks again for the help! I will do this. I really appreciate it!! :)
