question about nmo mounts
FFRXing
Fairfield, CT
Are nmo mounts, and mounts that are
1-1/8 inch, 18 thread, the same thing?...just curious, as I don't want to buy the wrong mount ...thanx jim
FFRXing
Fairfield, CT
Will do...just one more question for you guyz....is it ok to mix and match nmo mounts with nmo antennas? For example, can I use a MaxRad nmo antenna, on a Larson nmo mag mount, with out any problems? Thanx JIM
KC2SVY
Should work, NMO non manufacturer is a standard to my knowledge.
wogggieee
Hugo , MN
I've used diamond antennas on Antenex NMO mounts with out any problems at all.
DiGiTaLD
NMO is an industry standard. You will also see them called Motorola mounts. It doesn't matter who the manufacturer of the antenna and who the manufacturer of the mount is. Its a standard design mount and manufacturer has no bearing, as long as it meets the NMO specification.
