Question about Pro 96 Open Mode
Doublet
IN.
When in open mode , and a ID of non-programed dept. pops up . how do i program in into a bank ?
mcema699
From the Manual Pg 38 (for future reference)
Each talkgroup on a trunked radio system is identifi ed by a
talkgroup ID. You can store talkgroup IDs automatically while
scanning the trunked system in Open mode, or manually by
entering the IDs directly.
To automatically store a talkgroup ID, press TRUNK when
the scanner stops on a voice channel transmission or
when a talkgroup ID is indicated in the manual mode. The
ID of the active talkgroup is automatically stored in the
next available ID memory location. Your scanner’s display
indicates where the ID was stored as ID save X-YY, and then
changes to ID#ZZZZZ, where X is the sub-bank number, YY is
the ID number within the sub-bank, and ZZZZZ is the stored
talkgroup ID code. If the ID has already been stored when
you press TRUNK, ID was saved appears on the scanner’s display
Doublet
IN.
Pro 96
Tryed the above , when i push Trunk when ID pops up , i get ID Hold On , i push Trunk again , i get Hold Off ?
Bucko
Marietta, Ohio
Pushing the trunk button while the 96 is stopped on a TG will enter the TG in memory ( has to be in scan mode not manual).
N8IAA
Fortunately, GA
Yes, the radio has to be actively scanning on the system. Pushing TRUNK or ENTER will accomplish the same and load the TG into your scanlist.
Larry
