Question about programming Trunked Frequencies
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Scan only the bank with Copperas Cove EDACS system. Then press TRUNK. Then use UP/DOWN through all 5 trunk frequencies. Do you hear any Control Channel noise on any of the frequencies? If none is heard,
1) you may be to far from the tower to pick the system up
or
2) the database may be incorrect
DickH
Can someone take a look at the Copperas Cove, TX Trunked frequencies and tell me why these freqs aren't working? Is it because they're operating on EDACS Provoice and Analog? My PRO-2032 isn't able to scan these freqs right? Just wanted to make sure. I got them programmed in correctly, but I'm not getting any action on those. Just the Bell County Trunked freqs. Thanks so much. Art
Copperas Cove. There may something odd about that system. If ask in the Texas forum, someone there may know.
You talk about hearing Bell County FREQS, If you are seeing freqs. and not seeing Talk Groups on the display, it is not trunking properly.
cabindoor
El Paso, TX
Thanks for the help guys. Dick, I'm seeing the TG's when I listen to Bell County. It's just when I plugged in the Copperas Cove Trunked freqs, I don't get anything at all. I'm workin on narrowin the problems down with a little troubleshooting, though. I could possibly be too far from the tower, but Copperas Cove isn't all that big. I saw a snippet about how Copperas Cove is in the middle of switching to a new system but don't know how true that is. Thanks for the help again, though.
Art
fmon
Eclipse, Virginia
The later 2052 scanners can receive both conv and trunk in same bank.
DickH
Art,
In case they have rebanded, try this. Go to an empty bank and put in the new freqs.
CH. x01 861.20000
CH. x02 852.43750
CH. x03 853.47500
CH. x04 853.73750
CH. x05 853.03750
