Can someone please tell me why I cannot get on the RISCON. All the feeds seem to be down.
this is what I see on the RISCON(Rhode Island Statewide communications network). The DEC(decimal) should be blue, and the entire site is notWhat specific feeds can't you get into? All but 2 in the state of Rhode Island are showing online...
Also any pertinent error info on your end would be helpful to know
thank you. Powered was the wrong terminology to use in my case. thank you again, I will hit up the aboveNo, RISCON is not powered by Broadcastify. Broadcastify is just the delivery platform for listening to the system. When a DEC talkgroup is blue in the database, that indicates that the talkgroup has been captured by the Broadcastify Calls platform in the last few hours. All Brocastify Calls nodes and traditional feeds are provided by volunteers (like me).
See this post from Lindsay Blanton on why a feed/calls node may be offline:
Why is this feed offline? Why did a feed get deleted? How do I report a problem?
It looks like RISCON is provided by 2 Nodes and they both havent seen activity for 1 day. For this issue, I recommend reporting this problem to the node owner to see if they can resolve the issue as explained in the post above.
I don't think I have done that, and if I did, I was not aware and apologize.And using the Report button underneath a post sends an email to the Forums Moderators who aren't affiliated with Broadcastify in any capacity.
this is also what I see. RISCON is powered by Broadcastify, Cor
Good morning. I reached out to who I thought was a Node owner, and sure enough this is the response I got, 'No, RISCON is not powered by Broadcastify. Broadcastify is just the delivery platform for listening to the system. When a DEC talkgroup is blue in the database, that indicates that the talkgroup has been captured by the Broadcastify Calls platform in the last few hours. All Brocastify Calls nodes and traditional feeds are provided by volunteers (like me).
i am only a feed volunteeer my computer broke down the feed is no lonher being iffered sorry".
Sent from my iPhone. What happens now? Am I screwed not being able to listen
I would love to use a radio/scanner, but the cost is so prohibitive, I can't afford one. This is why I rely on this system. And yes I am in Rhode IslandTo answer your question, yes. However someone else might be interested in adding such a feed in the future. maybe an obvious question but not sure where you are in respect to the feed location, but if you are in RI, are you not able to use a radio to receive?
thank you for your response, and yes most of Rhode Island is simulcast on the 800.I certainly understand! There are some fairly good deals on used radios around but not sure if RI is simulcast..if not a good used bcd996 or 325 would fit the bill. I realize no radio comes cheap but I save money weekly in a small radio fund even after many decades for a hobby that is important to me. Good luck!
You would probably need a Uniden $D$-100/200 to receive it reliability. I live in MA on the outskirts of the system, and I'm able to get the north site on my old $70 PRO-197 using a Watson pre-amp. This is only because the other site locations are so far away that I can't get them so no simulcast jamming for me.I would love to use a radio/scanner, but the cost is so prohibitive, I can't afford one. This is why I rely on this system. And yes I am in Rhode Island
