Question on receiving calls
steve352
Ocala, Florida
If my county FD is transmitting on a trunked system and is listed as digital can I listen to them. Here is what I see on here...
Marion County Fire/Rescue Talkgroups
DEC HEX Mode Alpha TagDescriptionTag
1113 459 DEMCFR AllCallFire All-Call Fire Dispatch
1100 44c DEMCFR NorthFire North Region Response Fire-Tac
1101 44d DEMCFR SouthFire South Region Response Fire-Tac
1102 44e DEMCFR TalkFire Talk Around Fire-Talk
1103 44f DMCFR PrimaryFire Primary Fire Dispatch
1104 450 DMCFR Scene 1Fire Scene 1 Fire-Tac
1105 451 DMCFR Scene 2Fire Scene 2 Fire-Tac
CT
DECHEXMode Alpha TagDescriptionTag
1113459DEMCFR AllCallFire All-CallFire Dispatch
110044cDEMCFR NorthFire North Region ResponseFire-Tac
110144dDEMCFR SouthFire South Region ResponseFire-Tac
110244eDEMCFR TalkFire Talk AroundFire-Talk
110344fDMCFR PrimaryFire PrimaryFire Dispatch
1104450DMCFR Scene 1Fire Scene 1Fire-Tac
1105451DMCFR Scene 2Fire Scene 2Fire-Tac
The capital E in the Mode column indicates Encrypted.
No scanner can receive those.
wtp
Port Charlotte FL
annnndddd, you would need a digital scanner to hear digital signals.
what scanner are you using ?
Enjoi19
Ontario, Canada
steve352
Ocala, Florida
So my bcd396xt can hear these correct
steve352
Ocala, Florida
steve352
Ocala, Florida
I followed the set up guide and when I hit scan it started to scan but says id search and below that it has NFM what did I do wrong????
tvengr
Well Known Member
Baltimore County, MD
You can toggle between ID Search and ID Scan by pressing FUNC and then SCAN. If you see NFM, you are not detecting the control channel. That could be due to having the wrong frequency programmed or possibly simulcast distortion. You have 2 trunked systems, one for Marion County and the other for Ocala. The Marion County system has 3 sites. What control channel frequency did you enter and are you using programming software?
hiegtx
Mentor
Dallas, TX
Marion county Florida
You are scanning a trunked system:
When scanning that system type (trunked versus conventional), your scanner is monitoring the control channel, and looking for talkgroups. When you see ID Search, the scanner will stop on any active talkgroup it finds in the system, with the exception of any that you have locked out, or that are in a Group that is locked out. Encrypted talkgroups are skipped as well, though once in a while, the scanner may stop very briefly on an encrypted TGID, but as soon as it recognizes encryption in use, it will resume scanning.
If, instead, you see ID Scan, the scanner will only be looking for active talkgroups that you have programmed, and that are not locked out nor are they in a Group that is locked out.
On the 396XT, you can toggle between using ID Scan and ID Search by pressing the Function key, followed by the Scan key.
MStep
New York City
I prefer doing ID Search as opposed to ID Scan when monitoring a trunked system. On ID Scan, if, for example, you are downloading from the RR database, you will only hear those talkgroups which are already identified in the database. If you use ID Search, you will also pick up talkgrounds which are likely associated with the system, but which not have been ID'ed (or tagged), in addition to the ones which have already been identified.
For me, ID Search makes for much more interesting listening. Some scanners, notably the SDS series, have the ability to automatically search for talkgroups within a system that have not yet been identified, even when the unit is unattended.
steve352
Ocala, Florida
yes its trunked
