Question - Repeater Remote Programming
dapaq2
Northwest Indiana
Anyone know what methods (IF ANY) are available to remotely change/update the programming on the Kenwood Nexedge series repeaters such as the NXR-710, NXR-810, NXR-700 and NXR-800 models. Curious if KPG-150 and KPG-180 OTAP can be used with these repeaters for remote programming. To hopefully avoid any misunderstanding I am NOT asking about the updating of the programming of subscriber units in the field such as portables and mobiles like the NX200, NX300, NX700 and NX800, I am asking about updating the programing of the actual repeater remotely.
k4ktr
Elizbethtown,kentucky
Ok That is a 2 part question. sort of what could you possbile want to change on a repeater remotely? because frequency and all of that is bound by the duplexer or combiner.
part 2 the only way to Remotely program the repeater is to have internet at the site with a static ip address and then the repeater if it is an nxr-/x10 needs to have a kti-3 for internet connectivity. same applys for the nxr-x00 but it has the kti built in. and also it only works if the repeater is set up in nxdn mode
dapaq2
Northwest Indiana
Thank you for your response K4KTY.
No my intentions for remote programming of the repeater is not for changing frequencies or sub audible tones but for all the other options such as for example user list, remote control, courtesy tone, etc etc etc...
OK, you have reinforced my findings that it can only do it via ip network link (internet) and OTAP remote programming of the repeater is not doable, which is unfortunate as I see no good reason not include repeaters in the supported list for OTAP programing functionality. I had a chance to try out the ip link remote programming last night and it seems to work well and is an option but OTAP would have been my preferred choice of options. Oh Well.
buddrousa
Changing the programming of a repeater requires several things.
1 Re tuning the duplexers
2 Checking the repeater with a service monitor
3 Checking the antenna SWR
4 Checking the receiver sensitivity
and a host of other settings that is a lot of money to just throw up in the air and hope it lands soft.
dapaq2
Northwest Indiana
I am well aware of that and what you just told me is true but only if changing the frequencies, which is NOT what I am doing as I previously stated.
dapaq2
Northwest Indiana
Who said anything about changing the RAN code? No, you just click on read or write under the program tab, no enabling programming mode required.
dapaq2
Northwest Indiana
Trust me there are several areas in the programming that could be changed at a later date. I have already given examples, done justifying MY reasons for wanting to setup remote programming.
kd4efm
EL98 Florida
Doug,
1 the OTAP programs you mentioned are for the subscriber units only.
2 internet, you will have to follow the guide on setting up a NXR-x10 repeater with a vpn router, with that said, then you can use KPG-129DN to
modify the setting and upload the code plug, You VPN into the site, then you can make the changes. The KTI-3 is not a plug and play to the internet. This has been discussed in great detail years ago in the yahoo group and on Facebook. This is a form of security for the repeater that
is built into the firmware / code. The code does not have ARP or NAT handlers and from kenwood, never will. Keeps the cost from being as much
as the NXR-5x00 repeaters that are meant for Type C Trunking. There is not much in the way of programming manual on this other than the
guides for the NXR trunking and the system guide.
*I know you said you tested that and it works, just explaining the main reasons why for others to understand who read this thread.
Also, Kenwood is still working on the 128 zone issues you sent me to have looked at, they are still working on it at the lab.
There is no such thing as otap for repeaters.
dapaq2
Northwest Indiana
Thank you for the additional information, Evans, appreciate it.
1. Yes agreeable that OTAP is only for subscriber units (base/mobile/portable) and does not work with repeaters. Kenwood feels the ability to change programming on a repeater remotely via OTAP is a security issue/risk and feels it be done locally at the repeater by the radio technician and not remotely over the air. I disagree and it should be allowed but nothing I can do to change that as OTAP would be very helpful for repeaters that are not able to have an internet connection at the repeater site.
2. I have a basic understanding of what VPN is and does, but as far as setting it up and using it that is uncharted waters for me so I will have to do some research and reading up on it.
