landonjensen
Quote-
you will need to know the paging tones used to activate the pager. You will need to connect your scanner to your computer sound card and decode the tones when they are sounded. On the back of your computer, there is a jack (mine is labeled INPUT). If you don't already have one, you need to buy a cable that will connect from the scanner's headphone jack, to the sound card jack. I can't think of the exact size of the cable off the top of my head, but it needs to fit the scanner's headphone jack. It's not hard to find either, just hit some electronics stores and shop around.
Question-
after you plug the scanner into the computer do you need a software or program?
p.s.
im not sure if this is where im sure i should post this, so correct me if i am.
Question-
p.s.
