question
73fd
I have a BCT 15, and i have a lot of frequencies saved in my scanner and i just want to know if you can just scan about 5 of them at once, and just those 5. How would i go about doing that. I tried finding it the the manual, but its not a very good manual, if you ask me. thanks for the help.
JnglMassiv
Chicago / 016
You have a couple of options but the easiest way will probably be to create a new group (or a new system, then a new group) and copy and paste only the channels you want into that new group. Then, you can de-select the groups with all the extra channels, select the new group and only listen to the 5 channels you wish to hear.
maalox
n y c
hi just add a alert tone to the channels you want to hear. then press function and 9 key while on hold. you will only scan those channels. with the alert tones. you can use priority the same way but you will get that 2 second delay.. no delay with the alert tone
