Everything went well. Downloaded Sentinel to my PC with no problems, updated firmware and database.
I created a favorites list in Sentinel and when I was finished, I couldn't understand the manual well enough to export it to my HP-2. After much reading and clicking around, I ultimately used the write to HP process. Whether that was the right or wrong way to import the list to the scanner, it worked, my fav list was in my scanner. I ejected the HP using my device manager, turned the scanner off, unplugged the USB and when I turned it back on to scan my fav list, it prompted me to go through the entire set-up process again. As if I had just un-boxed it, wanting my name/info, setting the clock, etc.
Did I do something wrong, that caused me to have go through the whole set-up process again?
Otherwise it is scanning awesome! Even with the stock antenna I was picking up a trunked system several miles away. Connected my Pro Comm mobile mag grounded to a pizza pan and its receiving even better. Going to experiment with my old RS mag antenna tomorrow and see how it does.
