ridgescan
That's not just a "desk" that's a STATION
I can't remember, what do you run for antennas bott? I'd sure like to know what rigs run on what antennas.
Get your paper towels ready. What I'm about to share with you is a pic that was posted to FB this evening in the R-75 group. And it is quite possible that one of the R75s in the pic is one I sold about a year and a half ago.
I would think it must be confusing with all four of them together like that. He could easily reach for the wrong radio when he wants to tune something in or adjust the volume.The owner of the 4 actually owns 6. Two are at other locations.
Yesterday morning my R75 was working just fine, until I decided to relocate it to a different part of the room, which was simple enough. I unplugged the power supply, disconnected the antenna, moved the radio to the new location, then reconnected everything. Making sure the power supply was live, I then pressed the receiver's power button ... nothing! Even the backlight didn't come on. When powering up the radio I would usually hear the click of a relay as well, presumably the antenna switcher, but I don't even hear that now.
I've checked the radio's internal fuse, which hasn't blown. The power supply's fuse is intact, as well. Not having a multimeter, I tested the power supply by connecting it to a 3-volt flashlight bulb, expecting it to burn out immediately, which it did.
You must have inadvertently replied to my original post from January of 2019, probably because the thread still has its original title. It has drifted a bit to various other discussions of the R75. A full year later I reported that when I brought the receiver back out of storage it no longer malfunctioned, so it's been working perfectly since January 2020. I suspect that the problem may have been an intermittent connection between the power cord and power supply that didn't show up no matter how often I tested it. At any rate, the R75 is functioning just like out of the box now, a full 22 years after I bought it new.When you tested the supply, where did you test it--at the power supply itself or at the other end of the cable where it gets connected to the radio? (You probably see where I'm going with this...) Also, depending on how easy/hard it is to open up the radio, can you test the voltage inside the radio at the radio's connector itself? I'm thinking that during the move, maybe a connection went bad: a cold solder joint opened, a previously pinched wire may have flexed enough to have opened (in the case of a wire going bad).
In other words: what happened during the move that could cause problems? When we've exhausted all of those options and it still doesn't work (possible, but not my first guess)--if you believe in coincidences--then something else coincidentially decided to go wrong at the exact time you moved the radio, in which case it might need to go in for repair.
Wiggle them enough and signals or power (or both) will drop out for sure when metal fatigue sets in.Thank you for the clarification! I'm glad to hear it's working again. Your solution brings to mind a trick I've used in the past called "the wiggle test"--wiggle connectors and wires to see if power (or signals) drop out...![]()
The R75 has a soul, loves to work its ass off and wants to live. That is all.You must have inadvertently replied to my original post from January of 2019, probably because the thread still has its original title. It has drifted a bit to various other discussions of the R75. A full year later I reported that when I brought the receiver back out of storage it no longer malfunctioned, so it's been working perfectly since January 2020. I suspect that the problem may have been an intermittent connection between the power cord and power supply that didn't show up no matter how often I tested it. At any rate, the R75 is functioning just like out of the box now, a full 22 years after I bought it new.
Somehow that remark reminded me of a Twilight Zone episode I saw many years ago, in which a guy gets so frustrated with his household appliances when they don't work properly that he starts swearing at them. The appliances then come to life and start chasing him.The R75 has a soul, loves to work its ass off and wants to live. That is all.
My second equipment problem in less than a year:
Has anyone else experienced this, or heard of it happening to an R75? The radio is more than 20 years old, so I suppose a component could have died, but which one, and why it gave out so suddenly, is a complete mystery to me.
Oops! I just noticed that this should have been posted to the equipment forum. Could a moderator please move it for me? Thanks!
Hi, Jerry with a J. This is Gerry with a G.Hello, I had my Icom R 75 which also quit on me a few years ago. Called the Icom repair center in St Joseph, Michigan and had my radio back in a week! Working like a charm. The owner is Matt Adrian and he’s quite a gentleman. I live in California, repair and shipping was totally fair. Contact me and I’ll provide his phone number.
I forgot what the problem was.
Regards,
Jerry
