R.Reference chat room
KB8UYC
Ypsilanti Michigan
what browser are you using??
Make sure that on the internet explorer you tell it to allow, and put it in the list and then come back and try
BobWeb
Thornton, CO
On Mozilla, you need to tell it to allow pop-ups from radioreference.com.
Tools | Options | Web Features
jerneedog
St. Charles, MO
As far as the chat room goes, I used to have SP Chat on my phpNuke site (it wasn't really used so when I moved the site to a new host, I didn't reinstall it) and it works good.
I've never used RW but My Gaming Clan uses TS.
IRC wouldn't be a bad choice either.
scanfan03
Houston, Texas
To exit DON'T PRESS THE X BUTTON ON TOP. I did that and couldn't get back in. It says that someone with the same IP address as me is on there and that it is probably because i didn't press the quit button. So now i can't get back in. The message says that it will reset in 180 seconds, but it doesn't because i exited it this morning at 1 AM Central.
kikito
North Pole, Alaska
scanfan03 said:
To exit DON'T PRESS THE X BUTTON ON TOP. I did that and couldn't get back in. It says that someone with the same IP address as me ....
I had the same problem but the only difference was that I had never login before!
In my case it was my browser blocking the pop-ups like erchambers pointed out.
scanfan03
Houston, Texas
I am not blocking pop ups. I got on yesterday morning at 1 AM but now I can't because i pressed the x on top instead of the quit button.
kikito
North Pole, Alaska
LOL! My point is that you might get the same "error" message for different problems.
You made your point very clear on the previous post which is to make sure you exit by pressing the EXIT button and not the corner X; I understood.
