R7000 Overheating Problem
riverrat373
Washington State
I did an experiment with my R7000 yesterday to see how to solve the high heat problem . I turned the radio on and let it run for about 30-40 minutes with a temp sensor laying on the top cover towards the back. The temp reached 90 degrees fahrenheit. I then set a small 12v computer fan to the side and towards the back where it would blow across the back of the receiver. The temp dropped to 81 degrees in about 10 minutes and stayed there for the additional 30 minutes of the test. I'm wondering if that will do the trick lowing the high heat without converting to 12v or actually fastening the fan to the back?
Just run off 12v .. considering that you do not need a 50A model for your R7000, you can find them for very cheap.
The service manual lists that 1.7A is required.
I just checked on Ebay .. and you can find them for as low as $2.
ridgescan
San Francisco, Ca.
I solved mine by running a "Hi-Fi Boxer" 110v ultra quiet fan placed right next to the rear ground lug, with airflow out. It draws cool air into the power supply side and pulls it immediately out the fan side, thus the internals never see hotness. The case remains so cool to the touch as though it's off. Very effective.
dkf435
Sweet Home/Foster OR
A actually got a small 486 CPU fan minus heatsink and changed the connecter to the Molex and plugged it into the back plug.
David
bob550
Albany County, NY
I've been running my R71 off 12V using a 3 amp power supply. I also run a Timewave DSP off the same power supply without any problems whatsoever. The R71 runs cool for hours without the background noise a fan would create.
ratboy
Toledo,Ohio
You can get the temps down on the outside with a fan, but to get the internal temps down to a decent level, you really need to run it on 12v. My 7100 was nice and cool outside with a fan, but inside, there was still components that were painful to touch.
kruser
Well Known Member
W St Louis Cnty, MO
I did both with both my R7000 and R9000.
I started with a fan but was not totally happy so I ended up getting the proper connector to plug into the shorting connector that were already plugged into the rear of both radios.
The only issue I ran into was with the R9000, it seems part of the metering circuit is taken before the internal supplies voltage regulator stage.
I think it was just the center tune function if my memory is correct.
It was not a problem really as my external source is very well regulated but the meter does not indicate center tune correctly if my external cells start to drop below the regulators drop out voltage. It does not drop out but of course can no longer maintain a voltage output unless I use some form of buck and boost power supply.
I don't care to use a buck and boost supply though as those are kind of like inverters where they are not 100% efficient and use some of your battery power. I can run at least three days as it is with many of my receivers powered on, a cell charger keeping the cell charged up so I can use it for my internet connection to a single laptop.
I strongly advise using an external supply with these old receivers.
Heat is a killer of electronics and with the age if these old Icom's now, an external supply just makes sense.
You can still run a fan to help lower self generated heat from some of the chips if desired but the radio may not warm up to normal temps so you may see some slight frequency error. Nothing a TXCO would not help compensate for though.
I always aligned my old Icom's using the internal supply set to the correct output voltage and then I'd set my external supply to equal the internals output at the same test point.
