I’d love to make a couple of these, do you have more detailed measurements?I've created a mount for my 2024 FORD EXPEDITION MAX. Do to the fact I have a lot of mag mount antennas. I designed it to be removable, can be mounted on the roof rail existing holes. I have painted several and they look good and I can put 4 antennas on the vehicle.
I have several I can sell you, my originals, at my cost to have made, $25 each with bolts. These were primed and painted flat black.I’d love to make a couple of these, do you have more detailed measurements?
I'd be interested in learning more on these. Just bought a 24 Expedition Timberline.I have several I can sell you, my originals, at my cost to have made, $25 each with bolts. These were primed and painted flat black.
They are steel, and wide enough for a round and rectangular mag mounts. You can install in the existing holes for the crossbars. For more clearance, they can be mounted upside down for more overhead clearance. For more particulars, just ask.I'd be interested in learning more on these. Just bought a 24 Expedition Timberline.
My 2010 F150 is so bad that anything below 10m is useless while the engine is running. I've narrowed it down to the injectors causing most of the issues.The California Highway Patrol (CHP), CA. Department of General Services Telecommunications Division (now part of Cal-OES), and Ford Motor Company collaborated and did extensive studies and testing regarding this subject along with the chassis grounding in the early 2000s because the Fords were notorious for causing RFI which severely affected the Low-band VHF Radios.
Traveling with 2021 Ford Expedition Max cross country. I have a couple of radios. My destination is a 7'0" parking garage where there is little to no margin for error. I KNOW that I've made it into these 84" garages at my 76.2". 7.8 clearance remaining though I rubbed something last time.They are steel, and wide enough for a round and rectangular mag mounts. You can install in the existing holes for the crossbars. For more clearance, they can be mounted upside down for more overhead clearance. For more particulars, just ask.
I am about to purchase a 2025 Ford Expedition Platinum. I am accustomed to placing mag mount NMO antennas on the roof of vehicles, but apparently the roof of the Expedition is aluminum, so that is out. I have also learned that the roof rack is mounted with rubber gaskets/washers. I do not want to drill to permanently install an NMO and in view of the above posts I don't want to do a fender mount (which was my original thought).I've created a mount for my 2024 FORD EXPEDITION MAX. Do to the fact I have a lot of mag mount antennas. I designed it to be removable, can be mounted on the roof rail existing holes. I have painted several and they look good and I can put 4 antennas on the vehicle.
Given the above information, how would the performance of a roof rail mag mount bracket in the dual band application rate? (I know it is not as good as a permanent installation to the roof) Should I look into purchasing a no ground plane antenna?
My 2013 Expedition has side windows that crank out like vents with a motor and also the passenger side has an AM/FM antenna plated onto the interior. Check yours before going that route. As far as the tint/metallization maybe you can measure with a UHF receiver inside and outside the vehicle at the glass.In my continued research I have found the LARSEN KG2/70CXPL glass mount. Seems to have very high ratings, but there are cautions about heavily tinted windows. My plan would be to mount two of them, one on each side on the rear side windows.
Very pricey indeed, but as I plan to keep this vehicle for a long time and also these antennas can apparently be transferred to other vehicles successfully, this might be the answer.
The question is how heavily tinted the OEM rear side windows might be and if they will create an issue.
Take MK's advice and drill the damn hole....Very pricey indeed, but as I plan to keep this vehicle for a long time and also these antennas can apparently be transferred to other vehicles successfully, this might be the answer.
Kind of out of my league with this, but wouldn't one of those 5/8 wave J-pole mobile antennas work without a ground plane?The roof rack/bracket is not going to provide a suitable ground plane.
It might work "well enough" for your specific use, but it's not going to work to its full potential.
For 2 meters, you ideally want a 38" diameter ground plane directly under the antenna mount. Hovering the mount a few inches above the roof isn't sufficient. The lack of proper ground plane is going to impact performance, make it difficult to tune, and likely result in the antennas being partially directional.
As noted, permanent mount on the roof is going to be ideal.
But if that is completely out of the question, then the 1/2 wave antenna is the way to go. Don't forget about getting coax into the vehicle. Pinching coax in doors/windows is going to be a long term issue.
I've not ever seen any 'true' dual band no ground plane antennas. Usually they are half wave on VHF, which will work, and UHF is some other design. Ideally a separate 1/2 wave VHF and 1/2 wave UHF antenna would be the way to go.
And then the scanner antenna, but likely not much of a concern for receiving only.
By the time you buy all new antennas, brackets, mounts, hardware and then deal with getting the coax into the vehicle, you might find you'll spend more money than just going to a local 2 way shop and having a professional do the permanent NMO mounts for you.
I know there are (plans at least) for DB J-poles. Of course the feed would/should still be from/through an NMO mount, so in any case, a hole has to be drilled somewhere.
I was thinking more of a case where the actual antenna couldn't be mounted close to the roof, like due to a desire to have the antenna higher (like on a luggage carrier, rack, or box or something else to get it higher), would a J-pole allow it to work ok without a proximate ground plane, or maybe even help out with reducing position problems (like needing to drill the hole off center to avoid a sunroof), but putting the antenna on a crossbeam of a roof rack in the center of the roof, (higher than the sunroof)?J-Pole antennas are half wave, not 5/8ths. Might as well use a standard half wave antenna on an NMO. It's going to be more durable.
Until I come up with a better idea....
