radio help in NC
rk62184
currently in boone north carolina
Hi, my name is scotty kidd and im a volunteer firefighter in boone north carolina and back home at asheboro north carolina. i recently got a radio off e-bay and when i sent it off to be programmed. they told me they needed more than just the frequency. so if anyone knows anything about randolph county or watauga county in regards to input frequency, transmit frequency, and pl tone recieve frequency with the repeaters i would be extremely grateful. thank you so much
scotty kidd
rk62184
help
that database did not have the transmit frequency, or the input frequency's. the data base only gave me the actual frequency numbers and the tone PL's. know of anywhere else i can go. and where you from in randolph county? im from asheboro and a member at westside fire and rescue.
jlh
Don't know, Scotty, possibly the FCC database? Someone else will know and jump in, I'm sure.
LA (Archdale).
hamstang
Charlotte NC
Hmmm, it has both input and output freq's when I go to that link?
hamstang
Charlotte NC
Ahhhh, I see the fire and ems freq's DON'T have the input freq.....sorry 'bout that
jeffmulter
Fort Mill, S.C. (just south of Charlotte, N.C.)
Scotty,
I would always suggest that you go through your department supervisors for the information that you are requesting, as well as permission to use a radio not supplied by the department on the specified channels.
It really is a cover-your-butt situation. If your radio does not work properly, or is stolen and someone else misuses it, you're less-likely to be putting your firefighting status on the line.
The worst time for your chief to learn you had a radio programmed outside the department is when your talk button sticks open, and puts a repeater channel out-of-service for a few hours.
Since we are talking about VHF for both departments, make sure the radio is capable of narrowband, splinter channels, digital coded squelch, etc. The radio may need all three capabilities to be programmed properly for some of the Boone / Watuaga Co channels.
Depending on what method is used to program the radio, get a printout of the programming from the person doing it. That will help if you need to have it reprogrammed at another time. Also keep your radio's serial number stored somewhere, in case the radio is lost or stolen.
Final suggestion ... if you have a channel programmed into the radio that the fire service is not authorized to use, have the transmit disabled for that channel.
Good luck with the radio, and at Appalachian State ... good school !
Jeff Multer
Fort Mill. S.C.
(occasioanlly monitor Watauga Fire and EMS,
- and ASU Maintenance, when things are slow)
BryanTheRed
NC
I agree with Jeff I know here in Onslow County we have to have permission form the Chief of the Squad as well has the Divison Head of EMS to use personal radios!
