Scanner Tales: The Regency Years
My interest in scanners started as a child on the early 1970’s when my dad was a part time police officer in the town I grew up in. He had a Plectron set up on the police channel (155.130) in use by our town and a few dozen other towns. Pretty soon however I couldn’t listen to them at night when he generally worked since they moved off to the then new Public Works channel (155.760) to avoid congestion.
Eventually Dad got me an 8-channel Regency TMR-8H VHF-high scanner. I still remember the channel layout, a couple of the channels had some area channels already since he bought it from a friend who worked for the police department in a neighboring town to ours.
  1. 155.370 “City” (Later renamed to (“Point to Point”)
  2. 155.130 Wheeling PD “Daytime” (shared with most of the area suburbs at the time)
  3. 155.760 Wheeling PW, PD “Night Channel”
  4. 154.430 Wheeling FD (before they moved to 154.445)
  5. 156.210 Lake County Countywide
  6. 155.730 Deerfield PD (just north of us)
  7. 155.700 Lake County Sheriff
  8. 155.850 Deerfield PD Car-Car
Eventually I went to Mykroy Electronics (Later renamed to 645 Electronics, reflecting its street address) and bought a couple new crystals. Mykroy, in Wheeling IL, was a special place that had all kinds of electronic parts, a huge selection of vacuum tubes (Valves for my friends in England) and an entire room dedicated to scanners and CB radios. They also had a section of a wall dedicated to the scanner frequencies used in the area, hand scribbled with corrections and additions inked in from time to time. The also had all the crystals for all the scanners of the day. I saved up lawn-mowing earnings for a few weeks and bought 4 new crystals and replaced the ones I was less interested in with these:
  • 154.680 The original ISPERN
  • 155.655 The new Lake County Sheriff dispatch
  • 154.445 Wheeling’s new Fire channel
  • 155.640 Cook County Sheriff
I had this scanner until my Junior year in high school when I blew it up in Electronics class (Anyone remember Tom Schonouer, WB9QII? He was the teacher and had a 2M repeater there.) I tried to connect the scanner to the repeater antenna to see how well it would work and must have reversed the power cord and smoked the thing. Literally. Half the components were burned to a crisp, most of the rest damaged by the resultant fire. We set off the school’s fire alarm as well, fun times!
Soon, Wheeling and other area towns started moving to T-Band (470.xxxx) and my old VHF scanners couldn’t hear them. I then got one of those 20 channel Regency ACT-R20’s. To fill it with crystals ($6 each) cost more than the radio so I was only able to get a few at a time. While still in high school I was hired as a POC (“Paid on Call”, basically a volunteer who got paid per call) firefighter and used my radio hobby to help maintain the Minitors in use by the FD. I also worked the Command Van on occasion, including some pretty big incidents.
Eventually I saved up enough money to put a two-way radio in my car for my firefighting duties. Several of us did this and one of our guys was a Regency two-way dealer so set us up with the RH256 16-channel programmable radios. By then I had 2 of the ACT-R20’s, one for the house and another for the car but crystals were bankrupting me so I traded one the 20-channel scanners for a new Regency M100 that shared a case design with the VHF mobile radio I already had. These fit nicely in between the seats of the car and even better when I got a Bronco!
Fast forward a couple more years and I got into GMRS so naturally I bought an RU256, basically a UHF version of the VHF radio I already had. These three radios looked great together, making a nice flat face when installed between the seats.
I had several other Regency scanners over the years, I was much more a Regency guy than a Bearcat guy for a while. Other than a BC250 and a BC20/20 I pretty much stayed in the Regency camp for a long time. I intended to replace the M100 with the brand new MX7000 in the early 1980’s. It was advertised to cover just about every frequency one could want, including the new 800 MHz. band a couple local towns were switching to then. The pre-production pictures in Popular Communications’ ads showed it in an identical case as the M100 so I figured it would fit right in.
A quick call to Communications Electronics, and my order was placed, they said I was the first order they had for this as well as the HX2000 handheld. They said the scanner should be here within 4-6 weeks and they would call when it was on the way. Well, they did and when it arrived a month or so later I found the case was much smaller than anticipated. It also have no mounting holes. I called CE and they said they were as surprised as I was, their info came from Regency and Regency provided the pictures, apparently that was a mockup or demo unit. They called me back a few days later and said that the manufacturer was actually AOR-Japan and they were able to acquire compression brackets for this. As I was the first purchaser they sent the bracket to me for free. It worked but it was not ideal. I decided to keep the MX7000 for the house and left the M100 in the car.
I also bought at the same time an HX2000, pretty close to the handheld version of the MX7000. I am not sure but I would assume it too was private labeled for Regency by AOR as well. These radios were extremely sensitive but not very selective and had the scan rate of frozen molasses. You could time the scan speed with a stopped clock. A buddy of mine bought the Regency MX5000, the same as the MX7000 but without the 800 MHz. band. It performed the same as the 7000 in speed, selectivity and sensitivity. I suspect they did the same as Bearcat did with their first 800 MHz. scanners and used a UHF to 800 converter.
The one scanner from Regency that I wish I still had was the HX1000. This handheld was one of the best performing scanners I had ever used but I sold it to buy the HX2000. I never quite got over that, it wasn’t until the BC200 that I had a handheld that good.
After the debacle with the HX2000 and MX7000 I started to lean more on Bearcat. I got the BC20/20 and discovered it fit the package shelf above the glovebox of my Bronco perfectly and it lived there for several years.
My last Regency scanner was that M100. Later I almost bought a RELM HS100 but someone else beat me to it. A friend had one and said it was extremely sensitive as well as selective. If you weren’t aware Regency sold their scanner line to Uniden who then pretty much dropped all the Regency designs and put the Regency name on some of the existing Uniden scanners. A few year later (probably after a No-Compete clause expired) the now-renamed RELM (Regency Electronics Land Mobile?) came out with a couple new scanners. RELM had retained the two-way radio business during the interim and made a line of VHF and UHF radios. These new RELM scanners were well received and worked great but they just could not compete with Uniden and Radio Shack for market share.
As a nostalgia piece around 2000 or so I bought a Regency TMR-8H at a hamfest and even scrounged up some crystals to set it up the same way my first scanner had been. Amazingly the frequencies were still in use for the most part the same way they had been some 30 years before, although some were now backup channels instead of mainline. I think I gave that away when I moved 15 years later.
Some of you might remember Wilson also had radios much like the Regency RH256 and RU256 called the “Citicom” or something similar. The local railroad junction tower (at DeVal on the C&NW) had one of these for talking to the Soo Line that crossed there. I also saw them occasionally at hamfests and even installed in a state trooper’s car during that time. I assume they were private labeled for Wilson for Wilson or perhaps Wilson was a subsidiary or related to Regency somehow. Someone here should know!
es93546
A Member Twice
Right Side of CA on maps
Had a Z60 , a whopping 60 channels!! 50 plus 10 FM broadcast. Back then all you needed was 50 to hear damn near everything.
It would seem like 50 was enough to cover everything, especially in rural areas where most of my scanning has been in. However, I was in a location in west central New Mexico where I could hear things at great distances. New Mexico had a lot of "sky islands" and those islands had repeaters on them. I could hear traffic from Santa Fe to Socorro and all the way up to Grants. I could hear some simplex traffic from Albuquerque, which was about 75 miles away line of site and 105 driving distance.
There was a mountain peak south of town where I had access to electric service. I worked for the U.S. Forest Service and sometimes I would get sent up there during thunderstorms to act as a lookout. There was a laboratory with a third story with 360 degrees of windows. I would use a good, mirror sighting compass to give them my directional readings like a regular lookout. I took my BC-210 up there and only had the whip antenna on it. I could hear the Lincoln National Forest to the southeast and the Apache Sitgreaves NF to the west. I was picking up repeaters from 150 miles of driving distance. The 210 only had 10 channels, but up on this 10,000 foot peak, 50 channels would only cover the federal natural resource agencies.
This was in the late 70's and early 80's and one limitation was the lack of information on the feds. Heck, even the state and local agencies had limited info in New Mexico. I can only imagine what a high capacity scanner with a modest antenna on the roof of that lab could pick up now. I moved out of that state in 1981 and the 80's brought a lot of new toys. I wish I had my ham license when I was in New Mexico, but then again, I remember most ham radios of that time required crystals and handhelds weren't all that good.
KDT5256
KDT6266
Luthersville, GA
Instead of trying to revive a 50 year old radio I would look at a used Kenwood, Icom or Motorola radio of newer vintage. For one the systems now use a narrower bandwidth that the RH256 cannot be programmed to. Second, the likelihood of that old Regency being on-freq or otherwise workable on a modern system is next to nil. The administrator of the radio system would probably cringe at trying to make that old workhorse workable again.
You are absolutely right.
I didn't realize the original RH256 design was that old. Mine was NB capable and compatible with the local analog system. I did not try very long or hard before I placed the radio back on a shelf for display as an artifact in my office along with other memorabilia from days past. I acquired a Baofeng UV-82HP, programmed it and it work nicely as a backup to our crosspatched LTE POC dispatch via 911iNET.
prcguy
I've had a few older Regency scanners in the early 70s, forget the models but from the mid 70s to the early 80s I worked in a CB/car stereo shop and bought new models when they came out. The last two I had was the ACTW10 "Whamo 10" which used the aluminum combs where you broke off teeth according to a programming book. The last Regency scanner I had was the Touch K100 and that was a game changer, just enter freqs and go. While working a the radio store I took care of customer returns and met with the traveling Regency rep all the time. I even remember the 7707 Records Street, Indianapolis, IN 46226 shipping address for Regency.
ratboy
Toledo,Ohio
I didn't have many Regency scanners. None at all until the HX-1000 came out. I bought an HX-2000 and the crunchy squelch was super annoying until I modded it. After that, I had mostly GRE and Uniden, along with Yupiteru, Welz, Standard, and some other oddballs. Uniden lost me for years after I had the truly awful BC9000XLT, which was a mess with the local bus company audible on many unwanted frequencies, and I had to add heat sinks to many transistors and regulators in it as they were too hot to touch. I had already stopped buying Uniden handhelds after owning a BC200XLT and a 205XLT and suffering the battery pack issues they had. After them, I decided no handheld that couldn't use AA batteries would be owned by me. I don't know how many trips with the 200/205's were ruined due to almost brand new battery packs failing. Eventually, I made a AA pack that went on my belt, with a coiled cord that I plugged into a pack that had the batteries removed. Most of my fondly remembered radios were GRE/RS.
wqmg930
Riverside
Radiomonitor 10 channel was a big hit - My dad was a police officer in Waukegan ILL - he put one in his PD unit and was a liaison with other departments. Back in the 70's
ladn
My one and only Regency was a TMR 8 H-L. It was also the first real scanner I owned. Great scanner, and 8 channels was adequate back in the early 1970's. Time and technology moved on and my next scanner purchase was a BC 101 programmable. I still have the Regency, but haven't used it in years since most agencies I monitored in the 70's have migrated to UHF and above, and P25.
Over the ensuing years, I've owned a few RS scanners, but mostly Bearcat/Uniden. Scanning just isn't what it used to be and I bemoan both the lack of competition in the scanner marketplace and the dearth of innovative and new designs. I still yearn for a quality "DC-to-Daylight" unit in a split mount design.
jjhendo
Eagan, MN, US&A
My grandparents had one way back when. I just got one off eBay. Trying to see if I can find eight frequencies to fill it..
kevinparrish
Nationwide South of Line A
Greetings, You may consider installing a crystal for NOAA Weather Radio in the vintage scanner... I've done this and the old TMRs work just fine in this application. And all mine are running on 12-volts DC only.
jjhendo
Eagan, MN, US&A
Was thinking of that, I'd have to have it locked out most of the time, though. Ha. Maybe. I'm just trying to get it going right now. The on/off doesn't seem to work and a light bulb looks to have been rusted in..
