Baofeng Radio Reference Downloaded files
joemayernik
I'm trying to import a downloaded csv file into my UV-82. I just got the radio and was able to import from chirp the NCOAA freq. I downloaded a file for summit county utah from this site and I can open it up in excel. Is this not a straight import or do i need to play and match up columns like they show on the NCOAA import? I would have thought that the files on this site would be compatible with chirp and just a straight import. Any insight would be appreciated.
alcahuete
Southern California
There is no reason the files on this site would be directly compatible with CHIRP, when there are quite literally dozens of different programming software out there. You need to make the columns match and make any adjustments just like with whatever import you used. It's usually just a quick cut and paste job to get things in the right format for your radio.
