radio sending multiple registrations
billy2047
📶 🕨 Ø T₁ ÆS Ⱬ ⬜ ᴴ L |→| 𝅘𝅥 🛰️ 🔋
SYS REG RFSD OUT OF RANGE NO COMMS
Hi all, I was monitoring a MOTO P25p1 system using DSDFL and noticed some radios will "flood" the controller with multiple registrations approximately every 3 seconds. Does anyone know why? It happens randomly and battery has full charge so i dont think it's the radio turning on/off itself.
I've also noticed some radios will de-register, then re-registers and affiliates itself back on after a 5 seconds gap. I wonder why?
BB
ElevatorsAndRadios
yarewesog
SoCal
I have seen some of the APX7000XE portables at work do this on a P25p2 system... not sure why. I thought maybe it was due to the radio being in an area of poor coverage. That was just a guess though... I am merely an end user.
billy2047
yeah indeed it's weird. the thing is whenever an "offending" radio tries to send multiple registrations to the controller, it causes other radios to "bonk" then users complaint traffic is not getting through
nd5y
Wichita Falls, TX
I have seen that happen but it occurs about once a minute. Sometimes several radios do it but not at the same time. I don't know if they are portables or something else.
There's similar with a P1 system I was logging. Every 5 minutes the same ID would register and affiliate to the same talkgroup. No deregister, just reregistering and affiliate, no other activity, no voice/data grants, never de-registering, no other activity. a "ghost" ID that only registers and affiliates to the same talkgroup. Then at night it would slow down to every half hour or hour and sometimes none at all, then back to every 5 minutes during the day. Strange. Last time I checked it's still doing this over a year, I suspect its been doing this maybe years
rescue161
KE4FHH
Hubert, NC
When we see this, it typically means that the radio is out of alignment. Another thing that can happen is the radio can key up, get a channel grant, but when it unkeys, the radio can be far enough off frequency that the controller never hears the dekey request, so talkgroup is held in a keyed state, not allowing anyone on that talkgroup to talk. It is infuriating trying to track down these radios when they do this.
SCFDCOMM
I have seen this via Genwatch, Ive noticed it oftentimes happens ion a fringe area. I will run the next radio I see do this on Aeroflex8800 and see how it looks. The tropo issues in the metro area dont help.
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
Or it's an old RELM on a multi-zone system (they didn't understand multi-zone and did all sorts of weird things on a SZ system).
wa8pyr
Staff member
Lead Database Admin
Ohio
+1 on this. Being out of alignment can cause all sorts of weird things to happen. I'd make a trip to the Aeroflex my first priority.
GTR8000
NY/NJ Database Guy
BEE00
There was a bug in APX subscribers many moons ago that caused this sort of behavior. I do not recall exactly which firmware it started with, perhaps R16, but we noticed this bad behavior with APX consolettes. Specifically those which sat idle (no PTT's) for weeks or months at a time. The system would send out the usual group affiliation query to see if the subscriber was still out there, and the subscriber would go ape **** in responding, transmitting tons of responses over the course of many hours. All of the consolettes were well within alignment spec, so that wasn't the cause of the issue we observed. MSI never issued a TSB for the issue, nor was it ever documented in firmware release notes...it just kind of went away at some point.
rescue161
KE4FHH
Hubert, NC
Just FYI, my experience is with L3Harris and Motorola subscribers on L3Harris infrastructure (10A7).
