radio shack 91
DAVE1933
I have a pro 91 i want to know what i can listen to ,how to program it ,and get it to scan i live in jasper county newton county area in mo,thanks
hill
Middle River, MD
PRO91 is very old and can only trunk track 800 analog motorola systems.
Also can monitor conventional analog.
Most systems now bring P25 now I would think would not much on modern radio system can be monitored.
tvengr
Well Known Member
Baltimore County, MD
The only thing you will be able to scan are analog conventional frequencies and the Western Communication Services 800 MHz Motorola Type II Smartnet trunked system in Joplin.
DAVE1933
can i listen to air and rail road on these thanks for the reply
DAVE1933
ok thank iam looking at sds 200 but i am s skeptical i know that law enforcement is en cypyed but the sheriffs office that is not p 25 phase 2 so what do you recommend
DAVE1933
ok thank iam looking at sds 200 but i am s skeptical i know that law enforcement is en cypyed but the sheriffs office that is not .p 25 phase 2 so what do you recommend
law enforcement using a moswin system which scanner would be recommend for jasper newton county and mo highway patrol
tvengr
Well Known Member
Jasper County uses a simulcast site. For that reason, I would recommend a Uniden SDS100 handheld or SDS200 base/mobile. They are the best scanners for the MOSWIN system. The SDS scanners are the only ones specifically designed to receive simulcast sites. Any other scanner may or may not work depending upon your location in relation to the towers.
  • Like
Reactions: wtp
DAVE1933
ok thanks for the help why is the sds scanner getting bad reviews
tvengr
Well Known Member
The SDS scanners are not all that great for analog conventional frequencies. However, they excel receiving P25 simulcast sites. I am surrounded by counties using simulcast sites and the SDS scanners are the only ones that will work. All others fail miserably and I have tried them all. You can use your PRO-91 for conventional frequencies.
mr10pt
Lowell, IN
Dave1933, off the top of my head you can listen to Keener/DeMotte and Newton County fire. The rest of Jasper, Newton Lake and Porter are either on Safe-T network or Lake County Simulcast whereas you'd need the SDS100 or 200. I have both. Don't have too much trouble with analog here in Lowell with external antenna. The 200 has much larger display, much better sound and has one heck of a learning curve compared to the old programmables. My opinion is that it's worth the investment if you're willing to put in the time. Baby steps instead of the final product which doesn't exist because we're always changing things...programming, set up, color display etc.... Don't use zip code scanning (my poinion) because you'll probably miss what you want to hear. Learn to program youself so you have control of your radio. Just my 2 cents.
DAVE1933
mr10pt
Lowell, IN
Uh oh Dave just saw MO. Im sorry, we have the same adjoining counties here in IN
But I stand behind my posting.
