FFSOD7189
Retired Fire Lieutenant
- Joined
- Aug 25, 2004
- Messages
- 104
Hello. I have the PRO-163 RadioShack scanner. I went under the "product support" tab for the firmware updates and I clicked on "PRO-163 and PRO-164 Trunking Scanners (Firmware Upgrade 1.10 for Boot Versions 1.00 and 1.01 (555KB)) ". I followed all the directions correctly. I extracted to the folder I wanted and I clicked on "CPUUpdater_20-163_164_v1.10 for Boot Ver1.00" and NOT "CPUUpdater_20-163_164_v1.10 for Boot Ver1.01" because I have "Boot Ver:F1.00" which is boot version 1.00. I selected the correct COM port (after verifying it was correct in device manager), I clicked on "test" and it said "This update utility contains version 1.10", I went ahead and clicked "update", but then it said "No data from the scanner. Please retry from step4". After I keep on trying repeatedly it keeps on doing this. Please help? I don't know why it's doing this….
I use the same cable 20-546 that came with ARC300 and can program the scanner just fine, I just can't upgrade the Firmware.
Thanks for your time and have a nice day!
