Radio shack pro-2096
tvengr
Well Known Member
Baltimore County, MD
Which agencies and systems do you have programmed? Did you program the scanner manually or use software? If you used ARC96, please attach your programming file so I can take a look at it. You will need to zip the file to be able to attach it. Click on Attach files and open the zipped file. On which frequencies are you hearing the static? If it is 460.550, the sheriff is P25 digital and needs to be programmed as such.
Scanman72
Morrissville
I programmed the my local police, fire , emt and state police manually and I hear static on all the frequencies.
tvengr
Well Known Member
Did you program the frequencies as conventional (not trunked)? The Sheriff on 460.550 is using P25 and must be programmed as such.
wtp
Port Charlotte FL
i have and old pro2001 that has started that.
it scans with static no matter what the squelch is set to and even with the weather channel in it.
it does seem to come around when the weather is cooler.
so i suspect a bad part, just have not had the time to start spot freezing it.
Scanman72
Morrissville
I had the same scanner once before with no issues. It was easy to program manually. When I received this one it had a odor omitting out of it.
moonbounce
Radio shack pro-2096 question. Hi everyone i just bought a radio shack pro-2096 scanner on eBay. The scanner is omitting a strange odor and when I programmed the scanner when it stops on the frequency all I hear is static. Any idea what is wrong.
Sounds like your squelch and volume control could use a cleaning, see if you can get some alcohol inside the controls it might help.
