Radio Shack Pro 94 (b)
drum0501
ogden utah
I am looking for help I have tried loading with many files I have for scanners using scan cat. I wondered if anyone has a working file that I could edit or replace frequencies and ids. I have really been struggling Myself and a couple buddies are in the same boat. We all have pro 94 (b)’s. If you are able to let me know where I can find one I can change the freqs later. This is tough because you cannot download from the scanner you can only load to it. It also requires usb cable but won’t show wired mode unless you have a mono adapter. We appreciate any help let me know I have many scanners dialed in. But I would like to get this working for my little boy.
wtp
Port Charlotte FL
i do not know much about that scanner, but here is something to read as someone else might be of more help.
also it would help if you posted the system/s you are trying to listen to.
to use a bunch of time to find out you want a digital system wold be a total waste
7202001 (1)Weber County SimulcastWeber, UT851.350851.950852.275852.300852.5875852.6125852.900
852.925853.2375a853.2875a853.9625a853.9875c
7202007 (7)Mount OgdenWeber, UT851.1875851.4375851.550851.7625852.3625851.150851.800c
852.075853.625a853.650853.875853.900
analog and P-25 in use.
you are in luck as most all Ogden is analog and only 2 talkgroups are encrypted.
tvengr
Well Known Member
Baltimore County, MD
The Pro-94 is unable to properly trunk track the UCA system in Weber County due to the 800 MHz rebanded frequencies. From the Pro-94 Radio Reference Wiki:
You can read about rebanding by clicking on the Rebanding link above.
