GBLOCK
I have a Pro 2096 scanner that will receive analog ok but will not receive digital. I ruled out reception and programming error as the issue because I cloned programmed this particular 2096 from another Pro2096 that I have been using for years which receives both analog and digital fine. I did a master reset on the unit in question and recloned it several times and still no digital. Its completely deaf on 800mhz trunking P25 and receives on occasion on a conventional P25 channel all while my other 2096 is receiving everything in its path. Same antennas, same everything....
Date code 10A07 running 1.3 CPU and 1.3 DSP
Anyone hear of this before and know if this can be repaired......? The scanner is in excellent condition, bnc jack is secure and no signs that the radio was ever taken apartl
