RadioFeed Version 2.5
ProScan
Software Provider
Ontario, Calif.
RadioFeed 2.5 just released. This is a small update to fix the Source Client Current Listeners count.
RadioFeed is a free program with two powerful features; Source Client and Web Server. The Source Client streams to RadioReference, IceCast, and ShoutCast servers. The Web Server doesn't require a seperate server to stream audio and/or folders & files.
Text Tags supported for the HomePatrol, BCD996XT, BCD396XT, BCT15X, BC346XT, BCD996T, BCD396T, BCT15, BR330T, BC796D, BC785D, BC780XLT, BC296D, BC250D, PRO-106, PRO-197, PSR-600, PSR-410, PSR-310, PSR-500, PRO-18, and PRO-107 scanners.
RadioFeed is available at http://www.proscan.org/ on the right side of the page.
RadioFeed Setup Instructions - The RadioReference Wiki
W8RMH
Feed Provider Since 2012
Version 2.5 will not install. I get the error message attached. I disconnected and closed my current Radiofeed and all other applications during the install attempt.
ProScan
Software Provider
Ontario, Calif.
Is RadioFeed running when installing the new version? Stop RadioFeed and then try installing.
[Edit] I see you closed radiofeed. Does the Task Manager show RadioFeed running? Try installing in another folder and see what happens.
W8RMH
I never had any problems with previous updates. If all this does is address the feed listener count I won't pursue it any further...I don't use that count number I use the Broadcastify site number. Thanks anyway.
ProScan
Software Provider
Ontario, Calif.
The new version can't overwrite a previous version because a file is "locked' or in use. The problem is not the latest but the one you are running.
