Radioid.net problems
jimvm
Olivehurst, California
I am trying to convert my 1n dmr I'd to a 3n type. I find the directions to be not working for me.
There is a problem logging in and the password function does not like me!
They (RADIOID.NET) give instructions that do not work for me!
Brandmeister does not work anymore either.
I am using a pi-star hot spot.
Anyone offer help?
Jimvm
BinaryMode
2600 dialtone blvd
Are there any errors on screen?
What EXACTLY does not work so we know what the possible issue is.
Love your avatar by the way. ;)
From an AI.
To convert a 1N DMR ID to a 3N type, you can follow these steps:
1. **Login to RadioID Dashboard**: Go to the RadioID.net website and log in to your account.
2. **Access Your 1N ID**: Once logged in, locate your 1N ID in your dashboard.
3. **Convert to 3N**: Click on the 1N ID, and you should see a button labeled "Convert to 3n." Click this button to initiate the conversion.
4. **Confirmation**: After the conversion process is complete, you will be returned to your dashboard, and you should see your new 3N ID listed[3][7].
This process is straightforward and does not require any manual calculations or external tools. It's a case-by-case basis for approval, but converting an existing ID is generally supported for valid reasons.
Citations:
[1] DMR IDs - W9CR
[2] Changing D-Star reflector with DMR radio - SharkRF Forum
[3] Home
[4] DMR Teir III Trunking- DMR Tier 3 - Hytera
[5] Converting a Flat Number to a DMR ID
[6]
[7] Important message for Brandmeister USA hams using a Radio ID starting with 1 – BrandMeister DMR News
[8]
And just to be sure, the Pi-Star has outward Internet access? Can you ping a website or IP address like 1.1.1.1?
