Radius M1225 questions
KN4HTC
Alright then!
I guess now I get to find a keyboard that uses a serial port instead of a PS/2 port ha ha. (It's a old one for sure).
wa8pyr
Staff member
Lead Database Admin
Ohio
Alright, so I found a free Windows 95 computer and I was able to get the software from Motorola.
One question, the computer does not have any USB ports, just serial ports. Do I need anything besides a programming cable with a serial port connector? In lieu of buying one, is it possible to make a programming cable? As long as I know what wires go to what, I'm halfway comfortable with the idea of making the cable.
Batwing Laboratories and http://www.batlabs.com/images/maxpin.gif
Cable for the M1225 is pretty easy; cut a CAT5 cable in half and use one end of it. You'll need a RIB to go with it, although you can make a RIB for the Radius/Maxtrac/M1225 series pretty easily too; there are schematics for simple ones in several places on the web.
Easiest is to buy the ribless cable on eBay, although most of the ones I see require the RIB.
