Radtel RT-880 HF question and CPS update
PA3AZA
Enschede
Thank you EAFrizzle! I was just going to contradict you (as I tried that obvious way many times already but without success), but I just tried again for a check and YES now it works! Don't know what has changed things, but never mind :)
PA3AZA
Enschede
Still I have to contradict you EAFrizzle, in that the Full Band Tuning mode would prohibit transmit. In my UV-98 Plus with V1.14 FW it doesn't, at least not on 10m/2m/70cm... Maybe a difference between the Radtel and the Iradio?
EAFrizzle
Bond. Ward Bond
SE de DFW
Yes, I did make a mistake there. In wideband RX mode, amateur bands are available for transmit. Only in RT-880 mode do you get open transmit across the spectrum.
