Railfan "Auto-Patch"
kc9fsh
EN54tf
I was looking at WI database tonight and noticed they have a few "railfan frequencies" listed, most of them are either ham or MURS. One entry really caught my attention though.
161.41500 AAR CH 87 Railfan Repeater Autopatch to Railroad Police
Does anyone know what this is? I highly doubt it is what the description says.
Railroads Scanner Frequencies and Radio Frequency Reference
62Truck
Ordinary Subscriber
Ø
A auto patch is a phone line that is tied into the repeater, so the repater has a phone number where the police can answer phone calls on, The mall I used to work at, at night we would flip the emergency line over to the patch so if any one would call it would ring over the radio and the radio would be come a phone when needed.
kc9fsh
EN54tf
I know what an auto-patch is, but what I don't understand/find unlikely is that the AAR has a frequency set aside for railfans to use an autopatch to connect to RR police.
62Truck
Ordinary Subscriber
Ø
idk maybe to report suspicious activity
mciupa
Canadian DB Admin
Moderator
I'm here a lot
In Canada, that is the Mainline End-to-End frequency for Canadian National (CN), it seems preposterous to have non-employees using it. :roll:
OpSec
All your WACN are belong to us
Monitoring the database
It was covered here before, last year sometime...search it out and you should find the thread. I don't remember where it is.
seligman
My personal opinion is that it's bogus. Even if it is "legitimate" (use your own definition here) there is nothing advantageous about publishing it here. Somebody is bound to get in trouble using this information the wrong way.
That said, I know of railroad radio shops doing some, shall we say, unorthodox things. I've seen railroad paksets programmed with both AAR channels and ham frequencies because the user is also a ham. Another time (this was funny) a radio shop reprogrammed management's radios one night and manipulated the PL tones for encode / decode so they could only talk to themselves. Everybody else could hear their chatter. I've also seen HF ham antennas mounted on railroad towers just in time for Field Day. LOL
Common sense should prevail in this case...
ecps92
Taxachusetts
There is nothing wrong with having Amateur frequencies in the Radio, if the Operator is licensed for them. :confused: If they are programmed in ALL Radios, then that is a different story.
icom1020
Go back to the original submission and see whats up or modify it to say autopatch and leave out the railfan part.
seligman
It's against railroad policy. That's why it was considered a no-no.
icom1020
Ah, so it's been ongoing. The submitter knows enough about the background to post probably because it requires the correct DTMF to access it so listening wasn't a problem. It's only direct if a special agent is nearby, otherwise they have to be paged out by the RR command center. I guess the concern would be someone who sees it as an invite to report via 146.xxx or direct on 87 which would be a problem. By the time one did the interconnect, a cell phone would probably beat all this. I'm thinking it was a novelty set up by a couple of railhams as an experiment to see how effective it would be. I would still want a cell phone for privacy.
