Ram Mounts
kcoleman
Tallassee, AL
I'm looking to get a Ram Mount set-up to install a PSR-800 in my vehicle. I was curious if anyone has had experience with the Universal X-Grip for a large phone.
I'm looking at the RAM-B-316-1-UN10U kit.
The rubber grips are 7/8" in height while the radio is easily 1". Does the X-Grip provide enough grip strength to support the PSR-800 or is there another device cradle recommendation that Ram makes that would be a better option. (So far I haven't seen anything.)
Thanks in advance for any input and suggestions.
Keith,
DJ11DLN
Mudhole, IN
The deep phone mounts work surprisingly well with these radios. Take the batteries out of your radio and run it on USB power, that will reduce weight somewhat and help keep it in place over rough spots.
Cognomen
Radioactive Zone
I don't like the look of the X-grip style mounts.
I made a cradle out of aluminum that uses the scanner's belt clip. Just 2 bends and a cut-out for the USB cable. Then added a RAM diamond, using counter-sunk holes so the scanner sits flat. Painted matte black to reduce reflections. Added a piece of guard tape used for protecting helicopter blades, where the belt clip slides over the cradle. The cradle can be attached to any RAM setup.
jonwienke
More Info Coming Soon!
VA
I've never had a problem with the scanner falling out of the finger mount, and I've driven thousands of miles with that setup, on rough roads and off-road.
kcoleman
Tallassee, AL
Excellent!! That's how I'm currently powering the radio in the car. I appreciate the response.
Keith,
kcoleman
Tallassee, AL
Impressive metal working skills Cognomen.
I think a bit more than I want to get into. But I do appreciate the reply and enjoyed the pics... good job!!
Keith,
cmjonesinc
I know several people using the x grip ram mounts on motorcycles to hold a GPS with no problems. I was surprised at how well they hold.
jonwienke
VA
Thanks for the input Jon. I'll take a look at this.
You're welcome. I would suggest leaving the batteries in, so the scanner doesn't shut down if the power cable vibrates loose, or when you are starting the vehicle. The mount holds things securely enough that the scanner isn't going to vibrate loose from the mount even if the batteries are in.
DJ11DLN
Mudhole, IN
Me either, but I'm a firm believer in Murphy's Law. I feel better about it without the batteries in the radios.
My old pickup had a basically useless slide-out cup holder at the top center of the dash. I made a slot in it with a Dremel and used to just slip the belt clip into it, similar to what Cognomen did with his custom mount, just not nearly as pretty.:(
jonwienke
VA
That's ridiculous. The weight of the batteries is negligible relative to the radio, and the RAM finger mount is a honey badger--it doesn't care how bumpy the road is, the radio isn't moving. I've used them for years for scanners and HTs and they have never budged in the mount.The only thing that might budge them loose is a highway-speed collision, and the presence or absence of batteries will make zero difference.
You're more likely to damage the scanner by unceremoniously cutting power than by it falling out of the mount.
DJ11DLN
Mudhole, IN
Do as you wish, not gonna get into an argument, but just FYI, according to the specs in the back of the owner's manual, my Pro-18 weighs 210 grams without batteries. I'd have to presume that dry weight of a PSR-800/Pro-668/WS-1080/1088 would be very similar. Google says that size AA lithium-ion batteries weigh 25 grams each, for a total of 100 grams. I don't personally consider an increase in weight over "dry" of almost 50% to be "negligible."
But again, do as you please, this isn't worth arguing about.
jonwienke
VA
I use mine to hold a Uniden BCD436HP, which weighs about 390 grams with batteries and attached cables, and it has never shifted even slightly in the RAM mount, even when driving off-road on rough trails. The HT I carry in the RAM mount next to it weighs about the same and has never shifted either, even when pulling on the cord while talking into the speaker mic while driving on rough trails.
The weight of the batteries is negligible compared to the weight the mounts can hold securely even when pulling on cords while going over severe bumps.
bharvey2
That's nice work. I've got a PRO668 that I've been trying to decide how to carry in my truck. I use a cell phone mount but it seems flimsy to me. I may go the same route you did.
BigC801
Kansas City
Keith,
I use this ram mount RAM Universal Finger-Grip
Use it every day and they work great for the 436hp and TRX 1, Just got to set it so the power cable can hook up. Holds tight.
[/URL][/IMG]
[/URL][/IMG]
jonwienke
VA
I'd suggest extending the bottom support out as far as it will go, so that the scanner sits lower in the mount and the top fingers grip just below the menu button and port cover. That also gives you the option to add another finger on top for additional stability.
n3obl
ØAES-1024
PA
ive used the x grip for both my cell and handheld scanners. Works great with HD suction cup for window.
