Raymond J.Fisher Middle School Los Gatos Radio Frequency
Oakland_Tower
S.F. Bay Area
I have had good luck searching FCC files for the school district, then scanning those channels until you find your school. Best times to monitor are before/after school and lunch time. Some of the bigger schools have a local repeater on site, others may be simplex mode only.
ecps92
Taxachusetts
Raymond J.Fisher Middle School Los Gatos Radio Frequency how can I fine Radio Frequency Fisher Middle School
a. Have you actually seen radios ??
a. Type?
b. Antenna ?
b. Search the FCC (being licensed, does not equate to used)
Plug em all in and listen
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
I would start by going as close to the school as you can and using close call.
No, don't do this. If you're caught you could face some heat, especially these days...
TonyHolm: Try WQFB910. DMR may be a possibility so be sure your receiver supports it. Two fixed bases listed on the license for the middle school's address
7461.737500007K60FXEFB2163.00037.23383-121.96722LOS GATOSSANTA CLARACA
11461.5750000011K2F3EFB2130.00037.23169-121.96758LOS GATOSSANTA CLARACA
11461.575000007K60FXEFB2130.00037.23169-121.96758LOS GATOSSANTA CLARACA
Don't forget to submit your findings to the database ;)
