RCMP nationwide trunked system Sys ID 99B
gary123
This system is super active in Ontario. Recently we have discovered that it is also active in Quebec. This being the case it is not unreasonable to assume its also active out across the country. Maybe not everywhere but perhaps in the larger cities.
Here is a short overview on the system.
All sites are using the 99B system ID. All discovered sites have a neighbor list. All sites have their control frequency in the 421-423.5 frequency range. All TG on the system are encrypted BUT do not let this stop you from capturing the local sites. Interestingly the Encryption keys change about once a month. There is a good thread on the Ontario portion of this system in the Ontario forums. The TG although unknown in use can be semi identified by seeing what TG is used where.
Forum posts
Database entry
The best way to capture this system is using DSDPlus or DSDFastlane. You can also use a scanner and use the discovery and analyze options.
If anyone wishes to share their DSDPlus.p25.data, DSDPlus.groups and DSD.event files via DM I will sort through the information and submit the filtered results to the system data base for the community to enjoy.
gary123
It looks like the Quebec sites are starting to get discovered. This is the current list. NOTE this list includes several sites that are not yet in the DB. This is because the CC frequency is currently unknown. The unknown site numbers were located by using the neighbor list. FYI the unknown neighbor CC frequencies may be found in the DSDPlus.P25data file
007 (7) Trudeau Airport Montreal
008 (8) Quebec Location from neighbor list
010 (A) Deserotno
011 (B) Quebec Location
016 (10) Quebec Location from neighbor list
017 (11) Quebec Location from neighbor list
018 (12) Quebec Location
020 (14) Mont Sutton
022 (16) Drummondville
023 (17) Notre Dame de Grace
024 (18) Quebec Location from neighbor list
025 (16) Quebec Location
029 (16) Olympic Stadium Montreal
032 (20) Quebec Location
033 (21) Quebec Location
064 (40) Quebec Location
It is also believed that some of these 13x sites near Ottawa may be in Quebec such as Gatenaeu
130 (82) Possible Quebec Site
131 (83) Possible Quebec Site
132 (84) Possible Quebec Site
133 (85) Renfrew
134 (86) Possible Quebec Site
135 (87) Possible Quebec Site
136 (88) Possible Quebec Site
137 (89) Possible Quebec Site
138 (8A) Possible Quebec Site
139 (8B) Possible Quebec Site
140 (8C) Possible Quebec Site
141 (8D) Possible Quebec Site
142 (8E) Ottawa
143 (8F) Possible Quebec Site
144 (90) Possible Quebec Site
145 (91) Possible Quebec Site
We are also seeing that the Quebec Sites are using a lot of TG in the 3xxx range.
If some of our Quebec members can do a little monitoring (421-421.5) and can locate some more data it would be nice to add it to the main DB. Also no one has checked in with any information out of Edmonton, Calgary, Winnipeg Vancouver etc. It is possible the system is not yet active out in that direction.
gary123
I just heard a rumor that there are 3 sites in the Quebec City area. Could someone there capture a DSD FMP24 spectrum display or do a 421-423 search with a scanner looking for SID 99B.
