Reading data from TRX-1
safetypro79
Scanning since 1967
Anchorage-Alaska, Boise-Idaho, Salem-Oregon
Thanks, I did try that first as it was the best option and while I am getting local P25 and conventional traffic on the radio for some reason it’s not appearing on the ez scan db when I check the top column trunked or conventional freqs?
Wackyracer
You can only copy the configuration (all the setting and programming), for data you will need a logger such as whistlers "Control Demo" and have the scanner connected to a PC while using it.
