Rec output for stream
Ret_Batt_Chief
Windsor,ca
I currently use headphone jack to output audio stream on 15X using USB sound adapter. Was trying to play around with using to REC jack to I could still listen to scanner while streaming. The problem I'm having is when connected to REC jack I'm not getting audio output to stream. Any suggestions?
ProScan
Software Provider
Ontario, Calif.
At the system level, set the Record option to 'All Channels' or 'Marked Channels'. If Marked Channels then at the channel level, set the Record option on each channel that you want audio outputted.
ProScan
Software Provider
Ontario, Calif.
System level? Proscan or computer system?
You can do it in ProScan or the scanner.
If you make changes in the scanner then download afterwards so everything is in sync.
If you make changes to the ProScan database then upload afterwards so everything is in sync.
eaf1956
Evansville, IN
To put it in simpler terms: Audio is only output to the REC out jack on channels which are selected to REC
