WS1065: receive question
BK98260
Have a 1065 and was working great. I moved the unit and now there is no reception. the signal bar does not show, the weather receive wont even pickup.
this is a new unit, programmed from Radio reference. I reprogrammed it and made no difference.
I've tried different antennas and moving it back to where it last picked up, no change.
Anyone else experience this? is there an easy try or fix?
Thanks....
sopranosno1
Try this
Initializing to Factory Defaults
You can initialize the entire scanner to factory defaults.
This clears all programmed data and global settings.
NOTE: You can save your working memory to a
V-Scanner folder before performing this operation.
V-Scanner memory is not affected by this procedure.
To initialize to factory defaults:
1. Turn off the scanner, then turn it on again.
2. When the Welcome/Ownerscreen appears, press 0.
3. Press 1.
4. Press ENT.
5. Press any key to proceed. The scanner reboots
with file system and global parameters reset to
factory defaults
eyes00only
Denver Colorado
Make sure you didn't break the fragile antenna pin connector. With squelch full counterclockwise and volume
all the way up you should get weather broadcast.
dispatch235
Central Missouri
Be sure you didn't accidentally turn on the Global Attenuator ... mine won't even pick up but the strongest signals nearby with it on...
