BCD436HP/BCD536HP: Reception has ceased
ratboy
Toledo,Ohio
The quality control on the 436's (Probably the 536's too, but I don't have any experience with them) is pretty bad, I've seen a couple of suspicious looking solder joints on the two I have opened up, along with all the other problems they have. At least I was able to fix the speaker rattle and cutout on one of them without it having to go back to Uniden for such a minor issue..
drexel
NE MS
bcd 436 speaker
Scanner is only 6 months old and worked perfectly until several days ago when nothing was heard on it. I plugged in some headphones and it came to life once again. Still wont receive without ext speaker. Any Ideas? Hate to send it back for repairs.
Voyager
Could be a dirty earphone jack. Try plugging and unplugging the headphones a few times. See if you get anything on the speaker.
BLAH
LA area
Humm... I just had the same thing happen to my BCD396XT , I posted a new thread on it to get some advice before I send it off to be fixed :(
BLAH
pro106import
Milford, Ct. perched high above Long Island Sound
BLAH
When that happens on my 396XT I take my speaker/earphone jack and plug - unplug it several times in and out of the headphone jack. It usually clears up the oxidation on the pins inside.
drexel
NE MS
Plugging the ext speaker in and out 4-5 times and front speaker working again. Thanks for the tip all of you.
drexel
NE MS
bcd436 speaker
Spoke too soon about no sound from front speaker fix. plugging in and out ext speaker fixed problem for awhile but went deaf again. sprayed some RS dust remover and it worked again for awhile and now is not. Any suggestions. Still in warranty.
BobWill50
Jacksonville, NC
I got my replacement BCD1436HP about 20 minutes ago. Unboxed the unit and uploaded my Favorites and I am back in business. Onslow/Jacksonville P25 and Viper P25 are loud and clear. I am taking a road trip to tomorrow and have the frequencies programmed for the counties between here and there. It is good to be able to hear the action once again. Thanks again for the advice and tips for hearing the action.
TonyOrlando
Orlando, FL
Bought a used 436 from amazon late last year. Within 3 months, my reception degraded to nothing. I tried a gazillion suggestions from the gazillions of posts on this subject with no success. I plunked down $80 and sent the unit back to Uniden for repair. I received a "refurb" replacement and the invoice just said the unit couldn't be fixed and was being replaced with no further explanation. So the replacement unit has been working great the last few months...until today. I've noticed the signal degrading over the last few days until the unit went nearly completely deaf again this evening. I've formatted the the memory card, reloaded data from Sentinel, changed cards, changed batteries, tried different P25 thresholds...all with no success. Not sure I care to spend another $80.
ratboy
Toledo,Ohio
The problems these radios are having is just sad. I don't know how or why it's so hard to make a receiver that...receives. My HP-1 would go almost totally deaf at random and for some odd reason, a hard reset, usually about six of them, would restore it to normal. When it would go "deaf", it could barely get the 162.500 WX that is a very strong signal here. I couldn't take it anymore and sold it. I think only one of my friends who bought 436's still has his, the rest are gone, and they went back to the 396 or the 106/651/PSR-500's that actually work well, no drama.
