Reception Paging
Eng21inefd
Hello all,
I got my codes for two tone programming from the county. The pager seems to go off when it feels like it it has to be in a certain spot or area to go off. Yes the anplified charger will help at home but what about when I'm out? What can I do to fix this? Dave any recommendations?
IAmSixNine
Dallas, TX
is the paging done on a P25 system? what band?
Is it done on a conventional analog channel that uses the pagers secondary antenna, if your referring to a G5 and not a G4.
This sounds less like a two tone issue and more like a general reception issue.
How strong is the signal your tones are being sent on?
Eng21inefd
500mhz band conventional and it is in fact a g5. The signal usually has anywhere from 1-3 bars on it. I can have my radio sitting right next to it with dispatch channel going off and the pager doesn't do anything.
mdsxfire
EDBM
Uxbridge, north of the river Thames
Is the squelch setting set to high? And isn’t there a setting for tone duration long vs short type of tones?
Eng21inefd
There is something for the duration which is set to standard motorola paging system and the squelch setting is set to low.
RyanVogt
Yes there are several different tone lengths, Motratola quick call 1 and quick call 2 are very common but there are may different lengths. My department uses quick call 1 indiviual call tone & voice. my pager is set for QC1 and CSQ squelch and it works just fine. I would try to find out from a system admin what tone system you use. or maybe try to record the tones and time them then refrence the chart found in the link below to see what tone system they use.
https://www.midians.com/pdf/tone-signaling-charts.pdf
Eng21inefd
We use a 2 tone system my pager is set up two tone csq I talked to one of the guys from 911 center they said it is a standard Motorola paging system
wildbillx
Cape May, NJ
Eng21inefd- First, is the pager showing 1-3 bars consecutive or when they are "toning out"? Second, do you have a pl or dpl set for your dispatch frequency? Also are you scanning multiple dispatch channels as silent scan?
Eng21inefd
No lockout codes at all. And the only things that I'm scanning is ems fire Dept and fire police and it's all on the same channel knob it even does it with just my fd knob
26m10
I have the same problem.
My fire channel works intermittently.
Tonight I had it set on and the pager crashed and rebooted.
