I'm new to Ham. I'm looking for specific recommendations for a vertical antenna for the peak of my heavy-gauge metal roof.
I'm getting a new Yaesu FT-5DR and want to get the most our of my reception and transmission. I may also get a higher wattage mobile unit to use in my truck and home.
I understand metal roofs can be a real benefit to ham if the antenna system is set up correctly. I would operate the radio(s) in the room just below the antenna, so the cable routing will be simple and short. What are some good options for antennas, mounting equipment and cables to work with my new radio? I'd like it done right for under $300 if possible.
Thank you in advance for your help! KC9HAH
