Record settings Whistler TRX-1
w0nwa
Phoenix Az
Hello I have been using record on a few channels if I do any freq changes or updates on the computer when I send to the radio it erases all the records I have set. and have to program in the radio by hand setting up record. Someone posted somewhere that you can program record a channel etc viea the software. I have looked everywhere and I see nothing in the Whistler TRX-1 software with that option
Wackyracer
When you make changes via the radio key pad , in ezscan select copy configuration FROM scanner/sd card...this will put all the scanners info in to ezscan.
