SDRTrunk Recording Folder Sort
NewbGuy
Kentucky
Is there a way to make SDRTrunk place calls into subfolders by talk group when recording?
Currently they all just go into recording and then have to sort through.
I’d like to be able to go to recordings and have a folder for TG A, TG B and so forth.
dave3825
Suffolk County NY
NewbGuy
Kentucky
Not sure but why not use Trunking Recorder and selectively playback what you want to hear?
I’ll check into that. New to this whole thing. I’d looked up Trunk Recording but wasn’t windows based so I’ll check out Trunking Recording
NewbGuy
Kentucky
Got that all set up I think. Could either of you assist in webserver setup? I have Rdio Scannear running through Tailscale but unable to figure out Trunking Rec.
JimmyJet727
W4GXO
Carolinas
So are you running Mac or Linux? I'm looking for a similar solution for sdrt on Linux Mint. Any suggestions would be appreciated.
NewbGuy
Kentucky
I’m running windows, Lenovo Thinkcentre. Possibly Trunk Recorder might do yours. It’s Linux based. I’m not a Linux guy so wasn’t able to use it.
dave3825
Suffolk County NY
This may work for you. Will run on Linux.
Rdio Scanner is an open source software that ingest and distribute audio files generated by various software-defined radio recorders. Its interface tries to reproduce the user experience of a real police scanner, while adding its own touch.
