ProScan: Recording location
VE5JL
Saskatchewan VE5 Land
Is there a way to see where your recordings are going in ProScan? I see they're being recorded but I can't locate them on my PC.
I should add I have 3 scanners using the program and the newest recording are not in any of their folders.
Thank you!
ProScan
Software Provider
Ontario, Calif.
Thank you!
In the Recorder tab, see the last column"File Explorer". Click on that.
You can also go to Options Recorders tab and click on "Recordings Location"
dave3825
Suffolk County NY
If your just looking to listen to the recordings for all three scanners, and don't want to go into folders, you can set up Trunking recorder to import @ProScan recordings and pick each or all scanners to listen to.
