After updating the new Firmware on my 436HP I noticed a recording issue with the radio now. If you stop on a channel, talkgroup OR type in a frequency in manually and hold on it, the radio continues to record non stop between transmissions.
When the scanner is on scan mode it records normally and will stop recording when the transmitting has ended and when scanner starts scanning or searching.
Unlike the OLD Firmware where the radio would like be in "Voice Activated" mode and would record only when someone is transmitting then it will stop recording until the next transmission.
I'm guessing this an issue with the new firmware or am I missing something new here?
Fred
Fred
