WS1088: Regain scanlist names
kd5yuk
Wake Village
Used EZ scan software to do update from RR and lost all my scanlist names from #151 thru # 17 something. why did it do that and how do I regain the name list.
kd5yuk
Wake Village
change set location to off
That setting has never been changed.. so after all this time why need to change it now??
baker50021
Ankeny, Iowa
Response from Whistler
Check in your EZ Scan program in the General Settings tab toward the bottom right corner there is an option “Set Location”. Make sure that is set to “On” and then copy your configuration to the scanner.
You can also change this setting in the scanner. Press MENU to get to the main menu, then go to the “Program Menu” option and press SEL. Go to the “Global Settings” option and press SEL. Press the up arrow one time to cycle backward to the last option, which is “LocationSelect” and press SEL to enable the setting. Press MENU to exit, press SEL to save your changes when prompted. Press MENU again to return to the main menu.
With the Set Location option turned off, scan lists 151-200 are unlocked and you will be able to rename them. With the option turned on, the scanner will automatically name them to be used with location based programming.
Please let me know if you have any questions.
Bryan Hawkins | Customer Service Manager | The Whistler Group
