Regency MX4200
JESNYY
Riverdale, New York
I have a Regency MX4200 as a spare scanner, The backlight has burned out. Anyone know of how I may get the fixed. I know it takes a bulb. The blub I know is VERY VERY Small. Any ideas? Happy Holidays (JESNYY@aol.com)
KE7TJK
S.E. Washington State
You could try the parts bins at your local Radio Shack.
They had those small bulbs last time I needed one.
It was a bulb with the wires already attached. I cut the old pigtail off at the bulb, stripped the wires on the new bulb, and where I cut the old bulb off, and soldered them together, using heat shrink tubing to secure the connections.
Still working to this day.
I used a 12 volt bulb, which is what I needed in my application. You should check the voltage on yours before you buy a new bulb.
JESNYY
Riverdale, New York
Where would I find what milliamps are needed for the scanner? Thank you
JESNYY
Riverdale, New York
JESNYY said:
I have a Regency MX4200 as a spare scanner, The backlight has burned out. Anyone know of how I may get the fixed. I know it takes a bulb. The blub is a Graij of Wheat Bulb and are VERY VERY Small. Any ideas, what Milliamps are needed? (JESNYY@aol.com)
Every bit of help is needed.
