Regretting the Uniden BC125AT
kc2asb
NYC Area
Interesting insights, Jonandrew55. Thanks. I might give the trial a version a spin. I pretty much use my 536HP and 996P2 on a set it and forget it basis and do not monitor with a PC connected. With so much around me going E, the routine is more eliminating systems than programming new ones. :(
mobilelawyer
I got this scanner primarily to monitor aircraft. I live across Mobile Bay from the Mobile, Alabama Airports. BFM is only 5 miles away, and MOB about 10 miles as the crow flies. I hear plenty of activity from landing and departing aircraft and the control towers, approach control, and Houston Center, but the conversation tends to be one-sided: I only hear the in-air aircraft. I have purchased a second antenna from the stock one- the Diamond RH77CA. The Diamond is an improvement, but I usually can't hear the FAA side of the conversation. I am also going to try a longer telescoping antenna.
Years ago, I monitored the air band with a Sony ICF 2001 which was fed by a modified yagi TV antenna pointed toward the airport. It worked great. I think I tossed it when we moved 30 years ago, but I am hoping that I still have it stashed with other unused or deceased antennas in by garage attic boneyard.
Ensnared
Waco, Texas
There is a cheaper way to go than buying a digital scanner. You can look for a SDR setup. Some of these are available for around $100 or less. Airspy sells SDR. If I am not mistaken, you can monitor one radio system at a time. However, there may be more options as of late.
Since you live in ground zero for Tornados, you might consider programming the analog unit for Skywarn frequencies.
I hope you find a way to monitor. Good luck.
Lawton, Ok
Hi all. So my new Uniden BC125AT has only ever offered up some faint, staticky, garbled transmissions. I scan all the service channels, and have even used the software to program local ones to scan. In three weeks it's been 90% complete radio silence. Is it because I bought an analog unit which would be less than worthless when everything is all digital now? I was wanting to monitor fire/emergency because I live on an acreage in Oklahoma and we've had some bad fire days around. I didn't know this but is digital the only real way now? Thanks for any insight.
In case you haven't already entered these frequencies
Lawton, Ok
I thought maybe there was a chance they were similar to Comanche County. Both Lawton and County Fire still send the initial tone-out on the old analog channels at the same time as the trunking signal.
