Remote Head RH-96 Question
marktellez
Texas
Hi all!
So I finally have the cable from Uniden and was ready to go.
I connected the RH to my scanner and ...... nothing.
I can't seem to get the RH to talk to the scanner. I have looked through the user manual and it is a little vague and doesn't really give a step by step procedure. I have a feeling I may simply be missing a simple step. Any suggestions?
Thanks,
marktellez
Texas
I believe so. I made sure the front port was configured at the highest COM speed. Is there something else that needs to happen?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Have you checked the firmware version of your RH-96?
Older firmware will not work properly with the XT models.
marktellez
Texas
I think it has version 1.0 on it. I looked on the Uniden website and cant find a firmware update. Do you have a link to it?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I'm pretty sure it needs an upgrade to work with the XT.
marktellez
Texas
I searched on the Uniden site for an upgrade in firmware. Couldn't find anything. Any suggestions?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Type "RH-96 firmware update" into Google and a link to the firmware on the Uniden site will pop up.
fnnm400
Warren, Michigan
To UPMan, you are saying you can extend the data cable using a stereo ext. cable? I am building a new truck up and I need about 4 ft to make it work or I will have to remove the seat and cut the carpet to make the 10 ft work..
Toad_77
Yes, a stereo headphone extension cable will work.
Nessus
RH-96 Cable Pinout
Can somebody kindly post the pinout for the RH-96 [USB-4mini to 3.5mm Stereo Male] cable?
Thanks.
