AR5700D Remote Operation
G8OEO
Northumberland UK
I’m just starting to play around in a Visual Basic program with the commands for remotely operating the receiver and editing memory banks etc.
Unlike previous AOR receivers this one only displays REMOTE on the LCD display which often makes it difficult to see the results of sending commands without dropping back into local control after each one.
Can anyone who has played with the radio for longer than I have shed any light on whether there is some option for allowing the display to remain in it’s normal mode during remote operation.
AOR-262
@G8OEO
No - you cannot use the receiver when it's under 'remote' conditions.
I wrote software for the AOR 8000 (AR8000) handheld receiver and the AOR 8600 Mk2. The command list for the 5700D is based on the 5001D receiver. Much easier to write software for AOR products than Icom!
G8OEO
Northumberland UK
Yes I agree the commands are fairly straightforward for the AOR radios. I liked the command manual for the AR8600 because it had an alphabetical listing.
I know you can’t operate any of the radios locally when they are under remote control, however the others I still own (AR3000a and AR8600 mk2) show the normal display on their screens when under PC control.
I was hoping there might be a hidden option in the menus but haven’t been able to find one so far.
I guess I could send “EX” after each command when necessary to get around it.
AOR-262
@G8OEO
There will most definitely be undocumented commands within the 5700D.
I do remember finding out quite a few undocumented commands for the AOR 8000, one of which I do remember was only applicable if the DS8000 'Speech Inversion Decoded' was installed. That command was "SI" which sets the code for this option unit. It was possible to reprogram different scrambling keys for speech inversion. I never had the DS8000 and if I did, there were no scrambled transmissions I could receive to test.
There was a Group on Facebook specifically for the 5700D but I believe that Group no longer exists - there maybe others, I've not checked. Someone I knew who was then in that Group told me of 'undocumented' keypad combinations that would access a hidden menu system.
I've considered getting a 5700D but the only benefit I would have from owning that receiver is the ability to decode DMR. As I already own the AOR ARD300 which decodes DMR then it's pointless buying one.
Another 'BIG' concern was the firmware upgrading procedure. As you're probably aware, or if you're not (although things might have changed now) ... but not so long ago, maybe a year at the most? When AOR would release a Firmware update, the receiver had to be sent back to the dealer where you purchased your 5700D from. You couldn't take it to any dealer. The receiver would then be returned to AOR Japan at their HQ in Toyko. To date, I believe if I am correct, this is what you now have to do as there was only one UK AOR dealer who now no longer supports the 5700D Firmware update. Quite costly for 5700D owners to send their receiver back to AOR Japan whenever they release a Firmware update.
wb4sqi
Amelia, OH
There still is an AOR5700d facebook group and I am a member. As of this minute there are 124 members.
Is the programming in any way similar to the DV-1/DV-10 receivers?
AOR-262
wb4sqi
Amelia, OH
@wb4sqi
Yes, programming the DV1 / DV10 is simple.
Here's a full list of programming commands from AOR for the DV1 / DV10 (see link below ...). You'll also need a programming cable (see image below - can't remember the name/type of plug/end that you insert into the DV10. Am sure you'll figure that out.
http://www.aorja.com/support/manuals/AR-DV10_AND_AR-DV1_COMMAND_LIST_SUMMARY.pdf
I believe you misunderstood my question, I was asking if the programming commands for the 5700d are in any way similar to DV1/DV10. I already have a DV10 that I use with Wayne Taylor's free software that works very well. If the commands are similar then that could be a good beta platform for creating 5700d software.
G8OEO
Northumberland UK
AOR-262
@G8OEO
You are viewing documented commands - those are publicly available as per your link you provided. There will be remote commands AOR have not published. Without reverse engineering and memory dumping the logic chipset used in the 5700D you will never access those commands. Unless you are wishing to access and modify default settings it would be best you bypass any non-user commands as you run the risk of 'bricking' the receiver. My experience of this is completely blanking and re-writing the Bandplan of a blocked/USA AOR 8000 - re-writing the Bandplan so that the receiver becomes fully unlocked i.e. full frequency coverage from 100kHz to 2GHz (or whatever it was).
Back to your original post, stick with AOR's documented commands. It would seem as if you are suitably experienced in writing simple code albeit Visual Basic. It's the GUI you need to focus on - unless you are only writing the software for your own personal use.
Edit: Just to add I 'bricked' aka ruined beyond use two AOR 8000 receivers before I got it right. One command sent with incorrect data - at the price of the 5700D ... that's one expensive mistake!
AOR-262
@wb4sqi
No sir - I did understand your question. I did say "Yes, programming the DV1 / DV10 is simple". If you are in the game of writing software/code, sending remote codes to the 5700D will and is easy. Writing the code for your own use, again is easy - but distribute that software requires an appealing GUI. If you are up for the challenge you will make a lot of $$$. :D
G8OEO
Northumberland UK
@AOR-262
The software I write has always simply been for my own use and it’s only the fact that I enjoy combining radio with programming that makes it rewarding.
I must admit I hadn’t considered the possibility of bricking one of these radios by sending an unfortunate combination of commands and data. Thanks for the warning, I will be very careful to avoid any such errors in future.
wb4sqi
Amelia, OH
@wb4sqi
I am not in the game of writing code, I have zero knowledge in this area. I am only questioning whether AOR uses the same commands for the 5700d as were used in the DV1/DV10 radios. I assume that those who are knowledgable programmers would be able to answer yes or no. If yes, then there exists a base upon which to build programming for the 5700d.
bagmouse7
NC, USA
I have written some code for the AR5001 and I agree, the fact that the display changing to "REMOTE" is annoying.
I will also add here that the AOR control protocol has been very similar since the AR5000 days.
The DV1, AR5001 and later all share a very similar control protocol.
But, they are not exactly the same so you can't use a common control program.
An example of this is the "RX" command used to read the radio status.
The older radios returned the frequency as a string of 10 digits, the newer radios return this as a string of 11 characters with a decimal point in the 5th location.
AOR has most of the command reference guides here:
Good luck!
wb4sqi
Amelia, OH
Thanks bagmouse, that was exactly what I was looking for. I had assumed there were similarities but was hoping someone with knowledge would chime in with a comment.
jonnyfa
Felixstowe, Suffolk
I have a program that does NOT use the "Remote" so it is entirely possible. The program itself is no longer being maintained and not all of the finctionality works :
The software project that the author above created has now evolved into software by Martin Handl who can be contacted via the AOR5700D FB Group.
Hope that Helps
Jon
bagmouse7
NC, USA
I have used that same software from KMITOCTY.CZ and I was also surprised to see that is does not tie up the radio's display.
I think the author is doing a clever trick.
He probably sets the unit to "Auto Mode" (AU1 command) so he can update the programs radio display with the received frequency/etc., then he issues an EX command (end remote control) to restore the display on the radio and remove the "REMOTE" from the display.
I suspect that he sends the EX command after every remote command, which should make the radio display should look normal.
Do you know if the author of the software is also a member here?
Thanks!
jonnyfa
Felixstowe, Suffolk
Thanks!
I do not know if he is , I contacted him by email
Jon
G8OEO
Northumberland UK
I did toy with the idea of sending an EX command after each remote command but in the end decided It was obvious enough when my commands were producing the intended result without needing to check the display, so didn’t get around to trying it.
AOR-262
@G8OEO
You only need to send the EX command when you have completely finished using the receiver under remote conditions - to return the receiver back to user manual control. Sending the EX command after every command you send is pointless unless your reason is you want to check every command has been successfully sent and executed.
G8OEO
Northumberland UK
@G8OEO
Yes thats right, I really only wanted to see the radio display during initial testing of communications between PC and Radio.
As it turned out I managed fine without it so now I only send EX to log out at the end of a session.
