Remote software for tk7180
hackyman
Hello all, Recently we set up at Kenwood TK7180 up at a mountain top location to do some online recieving with. We are looking to see if there is any software out there or a way to control the radio remotely. I know there is software out there to control scanners just checking to see if anyone knew of anything for the TK7180. Their is nothing in the KPG89 software that I have found.
Mike
baycomm
Greenville, Delaware
The TK-7180 can be remotely controlled via the DB25 serial port on the back of the radio. Kenwood's KAS-10 AVL software has a utility that will allow you to adjust the front panel controls. Control is via simple serial commands that can be found in the appropriate manual. It is also possible to completely reprogram the radio via a remote connection to the serial port. To do so you will need to have a serial to Ethernet converter at both the radio & the programming computer. In addition, Fleetsync can be used to change channels via over the air commands. However, I don't remember if this requires special firmware.
