Remotely using mototrbo RM
Kenilworth IL
hi all
i have 2 locations and i want to be able to use the same rm server for both but do wired programing for both sites not OTAP. how would i do this? any help would be great.
Firebuff880
Boynton Beach, FL
Simply set up a Tech Laptop at both locations and buy two programming cables one for each location.
If you have Firewall or Connectivity issues between the Tech Laptops and the RM Server, I suggest looking at TailScale/Wireguard for a PTP VPN.
The Tech Laptop needs the Device Monitor/Programer only, and it needs to be set for USB jobs, among other things in the Setup screen.
If you want the remote tech to be able to update configurations and schedule jobs, then they also need the RM Client
In the RM Utility program on the server, be sure to set up authorizations, users, and roles as needed.
Firebuff880
Boynton Beach, FL
i got rm client working with the vpn but i can not get device monitor working on the same computer. any help?
Start the Program Go to Settings and set the FQDN or IP of the Server, Then test the connection.
Go to RM Server Utility and check the user and machines for the proper Authority if you get an Authorisation error in DP.
DP uses port -- 443
